Fixed the broken exhaust bracket, drove out to see some blooms.
Ok that’s good to know. I want to fix it right. Thanks for the help!The "correct" repair would be to replace the neutral safety switch and the engine wiring harness. The switch-side connector is not available, you will have to buy a switch to get it. the engine harness-side connector might be available. You would have to get the 5 digit number off of one to see if it is serviced. Individual repair splices would have to be obtained for the engine harness-side connector.
A new switch is around 200 bucks.
Get a weatherpack connector kit and redo the splice. Cheaper, just as easy, and when the repair is finished you are left with a cool tool and materials to properly do other wiring projects.Ok that’s good to know. I want to fix it right. Thanks for the help!
Eastwood Crimp-Right Weather-Tight Wiring Connector Crimping Kit
Install factory style weather proof connectors in your wiring harnesswww.eastwood.com
You can splice in any weatherproof connector.
eastwood is awesome they just sent me a case of thier 2 part rattle can spraySplicing in a set of mating aftermarket connectors is an alternative that is certainly better than what's there now. If you go that way get extra connectors And pins and make some good notes to remind you or a future owner how you did the job. When it comes time to replace the neutral safety switch you will be glad you saved that.
eastwood makes great stuff, they just sent a case of thier 2 part aresol spray paints. its actually catalyzed in the can, so I dont have to set u my hvlp setup and deal with cleaning. Im spraying some aluminum pieces i got from @ZeGerman as we speak. its good stuff, Im comparing the eastwood 2k against steel it.Splicing in a set of mating aftermarket connectors is an alternative that is certainly better than what's there now. If you go that way get extra connectors And pins and make some good notes to remind you or a future owner how you did the job. When it comes time to replace the neutral safety switch you will be glad you saved that.
what camera you using those are sweet pics brotherRunning around near Moab. Anyone here too?
Will do. I’m going to mark all of the corresponding wires before I pull it out. I’m amazed the transmission works at all with the current condition of this wiring. Thanks again for the help.Splicing in a set of mating aftermarket connectors is an alternative that is certainly better than what's there now. If you go that way get extra connectors And pins and make some good notes to remind you or a future owner how you did the job. When it comes time to replace the neutral safety switch you will be glad you saved that.
I use a OnePlus 6 and usually manual mode. Then color correct and sometimes add HDR using Snapseed app. Works great to get full range. Thanks.what camera you using those are sweet pics brother
Those Morel Nano's look Sweet! No way to get them with integrated tweeter?New stereo!
Kenwood Double Din, back up camera, Kenwood Amp, Morel Nano component speakers in the doors, which fit easily and sound amazing. Custom fabbed woofer under the passenger seat. Best sounding stereo I’ve ever had in a vehicle. Can hear it clearly over the KM2s. (We have five dogs, hence the dog hair.)
View attachment 1941283View attachment 1941284
