What did you do to your pig today?
90467-04100
plastic clip for the tailgate outside rubber....
So the outer rubber on Pig tailgates uses plastic pins vs. metal clips?
Still looking for p/n's.
Thanks!
I thought that was the p/n for the plastic clip securing rubber to outside of tailgate?
There can be no doubt...
I am seeking p/n for metal clip securing window felt to inside of tailgate.
Thanks!
That's the only clip pictured in my diagrams AND it is described as "Clip, Tailgate glass inner weatherstrip".
Perhaps the one you're looking for ONLY comes as a unit with the felt weatherstrip (that felt weatherstrip IS the inner weatherstrip as opposed to the outer weatherstrip).
Gracias Amigo!
Do you have p/n for little metal clips that secure window felt to inside of tailgate?
90467-04100 you need 14 of them
Thanks!
You could be right cruiser-guy.
This is what I am looking for:
It could be SOR only piece...
I'll keep y'all posted.
Had a bad death wobble with the 33X9.50 and chrome toyota wheels I picked up on CL. People said the passenger side front wheel was wobbling so bad it looked like it was going to fall off.
I repacked and adjusted the wheel bearings yesterday and it didn't fix the problem. I figured it meant trunnion bearings and a knuckle job.
As a last resort this morning I took it to Pep Boys for a wheel balancing. All four wheels were WAY out of balance, and the front right wheel was bent. They moved the bent one to the rear after balancing them.
It worked. I took it for a spin up to 65mph and no shudder. I am still going to do the trunnion bearings because it is worn, but at least it is now driveable.
You should be able to pilfer those from other felt inner weatherstrip pieces from the passenger doors.
removed and replaced the 4 speed transmission. Rolling again!
