Good Old PZJ77, 1993. Sorry for a bit of a download, didn't post progress as I went as just signed up today after checking out this site for a couple of years now...always was a bit slow and can't rush these things afterall.
to date, Fitted ARB Winch Bar, Rhino Pioneer Roof rack, Safari Snorkel, 2" Tough Dog Suspension Lift, Swapped out those dodgy electric motor front hubs for a set of 60 series hubs and AISIN Manual hub locks, X9 Super winch, BIG RED LED Spotlights + some rear work LED lights(not shown in the pic as old pic), Made extra long battery tray under hood to fit 2 main batteries [24V series system] + 2 more smaller 12v Auxilary batteries [in parallel] charged off
Redarc 24V to 12V charger at moment(may get a solar panel for when camping), An Aussie made rear bar that I scored off a Troop Carrier (has to tweak it a bit), modified tow bar. Got some tough black customs seat covers, especially to cover front drivers seat as the side had persihed so packed up with foam and covered with bit of old T shirt + contact adhesive (ados F3) before putting on outer cover(is quite comforatble now and can't feel the inner edge wire). Changed out rims to 16x8 steelies with Micky Thompson MTZ's that I got 2nd hand in pretty good nick. Blacked out the chrome front grille and side mirrors with that Plasti dip (was a bit sceptical but it seems to hold up well after a year). Also sprayed whole chassis etc... and engine bay, door panels (inside) with Corrosion X
To do (maybe)....
- Have some black colour(dye/paint) to black out roof liner and trims on door pilars etc... but not sure if I will do that?
- Wire in auxilary plugs at rear for fridge etc...
- Put another courtesy light in back so I can find things in the dark
- Sort out some more(or some at all) cup holders for front
- Replace rear door cards and cards in cargo area with check plate aluminium and spray black with ute liner (will spray side steps at same time)
- Pulled out faulty Air Con (perhaps bad idea?) but have air con pump still and may mount dive bottle underneath for onboard air setup (looks tricky getting oil to lube compressor and then remove oil after compressor...perhaps can run it dry if I don't run for long)
Wouldn't mind rear diff lock but don't really need for what I us it for and the missus would kill me if I do that before fixing the kitchen (or perhaps just kill me if I spend anymore at all on the truck).
