Definitely a better option.Calling Oursman toyota this morning to order the drive flanges
man! you can't catch a break...So the axle saga continues.....the new thicker drive flange leaves about 1/8" or so gap between drive flange and C clip groove. The idea of the axle being to back and forth im guessing is would cause wear issue's on inner seal ect.When compared to my original it's definitely a significant difference. Thoughts?
Pics are original flange vs new flange
Hope this pulls it tight.
Part should be here in couple days. I agree Rob, if it's needed then include it.
That deal David P found from trail gear at 50% off might be worth a try at that price.What an orderal. Hopefully things will be more sorted from RCV by the time that I do this
What year is your 80?What an orderal. Hopefully things will be more sorted from RCV by the time that I do this
You'll have same issues I did then. When you budget for chromoly axles, you'll need to buy a 95 to 97 drive flanges, ( i also got new cone washers, washers, lock ring and nuts, total from oursman was $300 includingdrive flanges), TG dust cap, rcv spline spacer, and a shallow m8x1.25 zerk fitting or you could plug it. This is if you go rcv. Not sure if TG or Nitro axles would be a different story.Its a 94
From reading I've done, you might want to go to a part time 4wd kit with the 300M axles. I'm not 100% sure on this but I remember that being a recommendationFrom what @matzell said, the TG axles are no longer made by RCV. I'll do more research before I buy but I'd likely get the 300M axles so I have no future worries when I go to 37s (in a few years)
