That's what sitting on my shelf. Im off this coming week, so should be able to get this done.
Marlin Inner seals are known to leak on the 80 for whatever reason. I do have the wits-end seal driver tool that allows you to set it a little deeper if there is a groove on your existing axle shaft. With the way the Marlin seal is designed you cannot drive it deeper. I just removed a leaking Marlin eco-seal and about to reinstall some I received from cruiser outfitters, so I have no real opinion on either style of inner seal.
Dave told me he had the exact same experience with the marlin seals. Rob told me marlin or bust. Who do I believe???
The seals i have now are from cruiser outfitters. So I'm trying the Marlin eco seal this time. This is the second seal from cruiser outfitters that has leaked. I am running chromoly axles too. So shouldn't have any wear issues.Marlin Inner seals are known to leak on the 80 for whatever reason. I do have the wits-end seal driver tool that allows you to set it a little deeper if there is a groove on your existing axle shaft. With the way the Marlin seal is designed you cannot drive it deeper. I just removed a leaking Marlin eco-seal and about to reinstall some I received from cruiser outfitters, so I have no real opinion on either style of inner seal.
Are you lubing the sealing surface with grease before installing axle?
I do a light lube of gear oil.Are you lubing the sealing surface with grease before installing axle?
Wheel bearing grease works better as it sits in the channel and stays put. Something is better than nothing, never want to put a seal in dry.I do a light lube of gear oil.
Plus one on this^^^Wheel bearing grease works better as it sits in the channel and stays put. Something is better than nothing, never want to put a seal in dry.
Wheel bearing grease now in inner axle seal channel. I wasn't to far from getting to it due to misplacing my fish scale last night. Beer and bourbon may have had something to do with the missing fish scale......Wheel bearing grease works better as it sits in the channel and stays put. Something is better than nothing, never want to put a seal in dry.
FANCY....be sure to lube those uni-balls after every wash and outing. They can get stiff.Slowly fine tuning the 200 with a dual battery system and some total chaos ucas to free up movement on the front getting rid of factory style torsion bushings. They hold up better but I don't mind the upkeep of regular bushings for the tradeoff on resistance.
View attachment 4113259View attachment 4113260
