Other than stock what other options are there? I need to keep my RPM's up when using the hot water heat exchanger.
Any suggestions.
Any suggestions.
rabid said:most of the guys I wheel with use PTO winches. They use a factory throttle pull set up to get the rpms up even and constant. works fine. Also nice when it is cold out and they don't want to sit in the truck to let it worm up.
DSRTRDR said:BTW I first tried to mount the hand throttle control in-dash using the one depicted in the other link. But there are some space issues as far as depth is concerned, you can only use certain holes in the dash, and I didn't wantt o drill a new one, and the one spare hole I had still did not allow for the required depth. But the little engine sign on the control know is cool.
