- Location
- United States
Ok, so some spring cleaning. Parts are all pictured at Cruiser parts sale - https://photos.app.goo.gl/ufzU4Gusfsh35CgM9 (some stuff pictured I have separate ads for, but if you see something in the pictures that is not listed, let me know).
All parts of for an FJ40, unless otherwise stated. Most items I'll ship, but have noted the ones I do not want to ship (big heavy stuff)...those can be local to Seattle area.
All prices do NOT include shipping. To make shipping easy, if it fits into a USPS flat rate box, I will use that. Shipping prices for those are:
Small box: $8
Medium Box: $15
Large box: $21
If it doesn't fit into a flat rate box (most stuff should fit, but a few probably will not), i'll let you know and can get a quote.
**Lastly, anyone who purchases at least $125 worth of stuff, I will pay for the shipping (except for brake drums).
If you want something, please send a PM so I can keep track of things and i'll keep this list updated (but make a note here on what you want so people know). Once something is claimed, i'll cross it out. If more than one person wants something, i'll go by who I hear from first. But i'll answer any questions about anything in this thread. If you want additional pictures of anything let me know.
Thanks...i've tried to price everything fairly and a bit less that what I see elsewhere.
Small box: $8
Medium Box: $15
Large box: $21
| Item | Price | Ship/No Ship | |
| 1 | Windshield hood rest pads | $10 | yes |
| 2 | $5 | yes | |
| 3 | transmission/xfer/dif seals (new, but not sure which exactly) | $10 | yes |
| 4 | Brake caliper kits (x4) | $3 ea | Yes |
| 5 | Steering joint plated parts | $15 | Yes |
| 6 | Brake proportioning valve | $10 | yes |
| 7 | FJ80 3FE fuel filter bracket (new powdercoat) | $15 | yes |
| 8 | Tubular tire carrier/latch | $150 | no |
| 9 | $40 | yes | |
| 10 | $10 | yes | |
| 11 | $20 | no | |
| 12 | window cranks - new aftermarket | $5 | yes |
| 13 | 8 shackle bushings ('79+) from Ironman Offroad | $40 | yes |
| 14 | OEM oil pressure sending unit | $50 | yes |
| 15 | $5 | yes | |
| 16 | ambulance door latches plated | $25 | yes |
| 17 | 3FE air injection parts plated | $20 | yes |
| 18 | drum brake kit (missing 2 pins) | $10 | yes |
| 19 | $10 | yes | |
| 20 | $25 | yes | |
| 21 | $15 | yes | |
| 22 | 3FE smog set complete | $100 | yes |
| 23 | running boards (rusty/dented) | free | no |
| 24 | front door headers (rusty) | free | no |
| 25 | FJ80 3FE motor mount cushion - new (right front 12362-61010) | $80 | yes |
| 26 | OME shock bushings | $10 | yes |
| 27 | $5 | yes | |
| 28 | various transmission/xfer gaskets | $10 | yes |
| 29 | Speedometer cable - stock length | $20 | yes |
| 30 | Speedometer cable - extra long | $25 | yes |
| 31 | $10 | yes | |
| 32 | heater pull firewall grommet | $5 | yes |
| 33 | rotor for 3fe distributor | $10 | yes |
| 34 | 1972 drive shafts (front and rear) | $50 | no |
| 35 | OEM 1978 FJ40 springs | $30 | no |
| 36 | $75 | Yes | |
| 37 | aftermarket barn door hinges | $25 | yes |
| 38 | FJ80 charcoal canister bracket and straps (newly powdercoated) | $50 | yes |
| 39 | 3FE air injector heat shields - powdercoated blue | $20 | yes |
| 40 | aftermarket rear view mirror | $10 | yes |
| 41 | OEM transfer shift boot - new | $20 | yes |
| 42 | brake booster check valve | $5 | yes |
| 43 | OEM right tail light lens | $10 | yes |
| 44 | $140 | yes | |
| 45 | 3FE right O2 sensor | $30 | yes |
| 46 | 3FE TPS | $30 | yes |
| 47 | 3FE exhaust bracket plated | $15 | yes |
| 48 | FJ40 brake line plated | $5 | yes |
| 49 | unknown plated bracket | $5 | yes |
| 50 | front door hinges x2 | $25 | yes |
| 51 | $10 | yes | |
| 52 | $100 | yes | |
| 53 | rear heater lines (rear heater is sold) | $40 | no |
| 54 | $75 | yes | |
| 55 | aftermarket antenna | $10 | yes |
| 56 | 3FE oil pump | $20 | yes |
| 57 | $90 | yes | |
| 58 | $20 | yes | |
| 59 | center console | $20 | yes |
| 60 | brake booster | $20 | yes |
| 61 | 2F engine mounts (x2) | $15 | yes |
| 62 | 3FE water pump | $40 | yes |
| 63 | new oem tsat | $80 | yes |
| 64 | $15 | yes | |
| 65 | $25 | yes | |
| 66 | Aftermarket brake drums from Cruiser Corps - set | $100 | yes |
| 67 | OEM brake drums - set | $50 | yes |
| 68 | used 3FE engine mount cushion | $15 | yes |
| 69 | Radiator | $50 | no |
| 70 | 3FE fan | $15 | yes |
| 71 | used 3FE intake hose | $10 | yes |
| 72 | $25 | yes | |
| 73 | steering column cover | $10 | yes |
| 74 | $25 | yes | |
| 75 | $15 | yes |
