For Sale WA - huge lot of parts #1 (FJ40 and some FJ80/3FE)
@Curtice if you're still watching this, interested in #29 (stock length speedo cable). Can you confirm the length is around 75"?
Hi all. Out of town til this weekend. When I get home I’ll check to make sure I still have stuff and let you know.
@aging fleet speedo cable measures at 75”. PM if you want it. Thanks.
Ok, so some spring cleaning. Parts are all pictured at Cruiser parts sale - https://photos.app.goo.gl/ufzU4Gusfsh35CgM9 (some stuff pictured I have separate ads for, but if you see something in the pictures that is not listed, let me know).
All parts of for an FJ40, unless otherwise stated. Most items I'll ship, but have noted the ones I do not want to ship (big heavy stuff)...those can be local to Seattle area.
All prices do NOT include shipping. To make shipping easy, if it fits into a USPS flat rate box, I will use that. Shipping prices for those are:
Small box: $8
Medium Box: $15
Large box: $21
If it doesn't fit into a flat rate box (most stuff should fit, but a few probably will not), i'll let you know and can get a quote.
**Lastly, anyone who purchases at least $125 worth of stuff, I will pay for the shipping (except for brake drums).
If you want something, please send a PM so I can keep track of things and i'll keep this list updated (but make a note here on what you want so people know). Once something is claimed, i'll cross it out. If more than one person wants something, i'll go by who I hear from first. But i'll answer any questions about anything in this thread. If you want additional pictures of anything let me know.
Thanks...i've tried to price everything fairly and a bit less that what I see elsewhere.
ItemPriceShip/No Ship
1Windshield hood rest pads$10yes
2Hood apron rest pads$5yes
3transmission/xfer/dif seals (new, but not sure which exactly)$10yes
4Brake caliper kits (x4)$3 eaYes
5Steering joint plated parts$15Yes
6Brake proportioning valve$10yes
7FJ80 3FE fuel filter bracket (new powdercoat)$15yes
8Tubular tire carrier/latch$150no
9Tire carrier cushion new OEM$40yes
10tire carrier bolt set overland metric$10yes
11Aftermarket rockers, unused but cut a bit$20no
12window cranks - new aftermarket$5yes
138 shackle bushings ('79+) from Ironman Offroad$40yes
14OEM oil pressure sending unit$50yes
152 bezel spacers oem$5yes
16ambulance door latches plated$25yes
173FE air injection parts plated$20yes
18drum brake kit (missing 2 pins)$10yes
19FJ40 fusible link set$10yes
20rear vent window brackets plated$25yes
21carb linkage parts$15yes
223FE smog set complete$100yes
23running boards (rusty/dented)freeno
24front door headers (rusty)freeno
25FJ80 3FE motor mount cushion - new (right front 12362-61010)$80yes
26OME shock bushings$10yes
27Dif deflector (x2)$5yes
28various transmission/xfer gaskets$10yes
29Speedometer cable - stock length$20yes
30Speedometer cable - extra long$25yes
31Transmission/xfer bearings (new, but not sure which exactly)$10yes
32heater pull firewall grommet$5yes
33rotor for 3fe distributor$10yes
341972 drive shafts (front and rear)$50no
35OEM 1978 FJ40 springs$30no
36set of barn door hinges and latch$75Yes
37aftermarket barn door hinges$25yes
38FJ80 charcoal canister bracket and straps (newly powdercoated)$50yes
393FE air injector heat shields - powdercoated blue$20yes
40aftermarket rear view mirror$10yes
41OEM transfer shift boot - new$20yes
42brake booster check valve$5yes
43OEM right tail light lens$10yes
443FE intake hoses & 4 clamps from city racer - brand new$140yes
453FE right O2 sensor$30yes
463FE TPS$30yes
473FE exhaust bracket plated$15yes
48FJ40 brake line plated$5yes
49unknown plated bracket$5yes
50front door hinges x2$25yes
51oem visors$10yes
52heater set complete with plated metal parts (firewall lines sold)$100yes
53rear heater lines (rear heater is sold)$40no
54fan blower set complete with plated metal parts$75yes
55aftermarket antenna$10yes
563FE oil pump$20yes
57brand new front heater core from cityracer$90yes
58defrost shields$20yes
59center console$20yes
60brake booster$20yes
612F engine mounts (x2)$15yes
623FE water pump and lower tstat housing$40yes
63new oem tsat$80yes
64used fj40 heater core - tested and works, but might not be as efficient$15yes
65SOR body mount kit - 95% complete - missing a couple parts$25yes
66Aftermarket brake drums from Cruiser Corps - set$100yes
67OEM brake drums - set$50yes
68used 3FE engine mount cushion$15yes
69Radiator$50no
703FE fan$15yes
71used 3FE intake hose$10yes
72taillight rock guards$25yes
73steering column cover$10yes
74new front door locks with keys$25yes
75Overland metric diff cover nut kit$15yes
how current is this list? Thanks
I still have most things not crossed out. But I am preparing to move and may not be able to find everything. If there is something you are looking for let me know and I can check.
Thanks,
Curtice
