I don't envision anything that nice for mine. Just an awning with zippers on all four sides, and 3 side walls that zip onto the awning. I have an ARB awning on the LJ81, so I can have it connect to that as well.
Just bought one of these from a fellow Mudder here in AZ. The one I have (some of you may be familiar) was originally built by a man in Texas who purchased the parts from the factory as they were closing up. I have been going through it and trying to identify any areas that need attention.
One thing that needs to be addressed right away are the struts that support the lid/tent when opening the top of the trailer. There are currently two different struts in mine as follows:
Spring Lift Corporation part # SL-37-20. This has a 20-pound lift.
SUSPA part # C16-12038. This has a 120-pound lift.
Can anyone verify which of these two struts might be the correct one? Just due to the weight of the lid with the folded tent inside, I suspect I want to go with two of the SUSPA struts, each with a 120-pound lifting force.
Also of interest with this one is that the tent sits 180-degrees around from the production models I see online. This doesn't seem to be a problem, just an interesting tidbit.
The inside access to the bed of the trailer when the tent is set up is just a sheet of plywood that is not hinged at all. I'd like to refine this a bit and get it closer to the production model. Looks like a fiberglass panel should be there.
If anyone has or would like to provide photos of the hinge assembly of the inside access panel - details and closeups, that would be great.
Looking forward to getting out there soon!
Share some pictures of what you have and maybe we can help you out.
The struts need to be strong, as in 100# each in force. I ordered the wrong struts the first time and had to order again. I still should have gone stronger. If you have the fiberglass lid then #120 is probably correct.
I’d like to get the opportunity to see one of these in action. Or at least a demo maybe one of you guys wants to bring one to a meeting?????
