Who's lift is that? It looks like Halo, but better.Yes the 4 post does eat real estate in the pole barn…this one accommodates our Suburban so it’s wide and long and extra tall. 9000lb capacity, rolling jack stand, and 5 sliding drip plates full length underneath for parking vehicles above one another without worrying if anything is leaking or spillage while working. Use 1 or all 5
These do not get floor mounted. They can be if you wish. Each 4 post leg has a weight driven, Cantilevered lever arm that when installed, the weight of the runways at the last 6-8 inches to the ground, will raise the posts so you can roll the entire lift left/right/forward or backward on the solid nylon wheels. You can also use their 12x12x1/2” thick rubber pads under each post to eliminate any abrasion to floor surfaces.
View attachment 3997980View attachment 3997981View attachment 3997982View attachment 3997983
Post #103Installing a two post lift with asymetric arms, figuring where to install it to lift a troopy. I imagine most vintage (4 leaf springs) frame looks the same, the lift point is just beside spring hanger? The front is a raising rail which is not great for a flat pad lift arm, do you have a special adapter?
Any one have a side picture of a 75 LC raised to have an idea of the post location in relation to the truck. My garage have about 23 feet free space so the lift must be at the right place.
Thanks
Were these flip up supports standard with your lift or were they accessory (upgrade) options that you selected?@lacalvette I can’t find a side photo of my FZJ75 pickup on the lift but here is one that sort of shows the flip up arms on the frame right at the spring perch, front and rear.
Standard but perhaps just standard for my dealer. The lift is a Rotary SPOA10 asymmetric with trio arms. The flip ups have a low and a high side. It also came with higher truck adapters that slip over the high side flip up adapters. Unfortunately all of these are metal on metal so I recently bought some round rubber adapters that slip over either side folded down.Were these flip up supports standard with your lift or were they accessory (upgrade) options that you selected?
Thanks
