Upon closer inspection, it appears that they only replaced the gaskets on the driver side. Passenger side seals look more like 350k than 5k, which is odd because I was charged for both sides...
Mistake or ThievesUpon closer inspection, it appears that they only replaced the gaskets on the driver side. Passenger side seals look more like 350k than 5k, which is odd because I was charged for both sides...
It may be worth re-torqueing the bolts now, using some penetrating oil from/on underside if any issues.I'm not leaking yet, but dreading the day I have to do this project, as I'm confident I'll have some frozen bolt(s) on my transplanted mid-Atlantic rig. Wrestling with busted bolts is no fun.
Maybe using some anti-seize on these when replacing will help if needing to remove next time. Wondering if a dab of high temp rtv on the underside to seal the hole would make any difference.
^Good plan!x2 on checking the torque on the bolts.
Every one of my bolts to my valve cover (with the exception of the stuck on) I could remove with a socket and my fingers, no wrench needed. I put some low strength loctite on them when reassembling to try to prevent corrosion.
2001LC, no go on putting the nuts back on, they stripped the threads of the stud. I welded on a nut, but where the shaft of the stud had been reduced it broke.
It left a little bit of stud left and I just welded another nut on there and it got a lot hotter (red) and welded a lot better. I then quenched it with liquid wrench. Waiting on it to cool off before trying to remove.
^Good plan!
I like to do a rapid cool down as well. The idea is to get the metals to move separately. Cooling just the bolt helps with this, then let cool down so both metals are cool. Keep pouring on the penetrating oil. If it moves a little stop add more P oil, then turn opposite direction add more P oil. The idea here is to work oil into thread.
Good luck.
I'm headed out to do a hitch bolt I've been working (heat/soak) since yesterday. The metal is sooooo dry!
