Just do all the things
The go no go gauges have a step on the end. For example the .016mm will step up to .017mm so you can feel the resistance. If you can get the .016mm into the gap but not the .017mm part then the gap is measuring at .016mm.are these any different than standard feeler gauges? i've got some old school ones here they look like this
Hi all,
Trying to tune the 60 but its proving difficult doing the lean drop with this aftermarket chinese carb I'm running with. Using a line from the intake I get 12 mercury, but i know the ideal range is 15-20. will this increase as I get closer in tuning this, or do I have vacuum leak?
Im leaning towards vacuum leak because If I hook up any of my other vac lines to this gauge it shows 0 mercury (no pressure, obviously). All vac lines should have roughly equal vacuum running through them, right?
I ran desmg, and there's a chance I hooked up something incorrectly, but I assure you all vac lines are plugged in, so not sure why a misplaced line would create a leak if its plugged.
Thanks,
Beehanger
12 inHg vacuum is very low. - unless you’re above 6000 ft elevation
Not all the vacuum hoses carry full vacuum all the time.
Connect the vacuum gauge to the small pipe jutting off of the brake booster manifold fitting.
Most of the well tuned cruisers around here pull around 15-16. I’m at 6k in Colorado. 12 seems low.
Some of those Chinese carbs are hit or miss. Some people have dropped them straight into the truck and they work perfectly. Others seem to have better luck replacing all the gaskets and seals with Japanese components.
Further more, some of the mating surfaces could be uneven and not making a seal internally. You could have a leak inside the carb. There could be gunk from the manufacturing process left inside. You might need to adjust the float to keep the correct amount of fuel in the bowl.
I was just chasing what I thought was a vacuum leak and it turned out to be out of adjustment valves, worth the check before you start pulling a bunch of stuff apart...
Have you checked your timing yet? Faulty timing, bad wires, misfires, too low rpm etc will do that. Try pinching off the vacuum booster hose, see if that fixes it. Same can be done with all the other hoses that you see coming off the intake. Otherwise, suspect the gasket under the carb. I got bit by that one a few years back.
Might be an unpopular opinion but I run gaskets even with the ones on the insulator. If nothing else it makes me feel better about not having leaks. There are two, one that goes between the carb and the insulator with 2 holes for the primary/secondary and a second that goes between the insulator and the intake manifold with one oval hole. I think City Racer may have them and I know Spector has them.
