Using Techstream to read codes?
Oakleyguy
Resident Engineer
Denver / Tulsa
Hi all, I have a bit of an 80 noob question that I didn't find a good answer with via search or Google-fu.
I have been attempting to read my codes using Techstream on my '96 80. I'm using "OBDII Datalink3" in the cabin above the fuse panel without luck. When techstream connects to the truck I can see the ECU and SRS/Airbag ECU, but I get this same message each time it tries to read (see attached picture).
I've also tried using the "generic OBDII" option to no avail. I can confirm the cable and software works with my '05 and '14.
Perhaps I've missed a step with the older truck or maybe my cable doesn't support the right protocol? Any tips or insight would be quite welcome.
-Nate
I haven't even thought about TechStream for the 80, just been using the ScanGauge II. The Techstream program I purchased only works with limited functionality on my 1999 100 series. I have been desperately trying to figure out how to turn the DRL's off on Georgine. Post up any success you have with TechStream on the 80.
Played around with this today. My old ScanGuage works great. No data with TechStream. TechStream seems to work on modern cars okay, but won't connect to anything on the FZJ80. Not even the "Generic OBD II" reader. Pity...
I'll echo the above: if anyone figures it out, post up. I couldn't.
I’ve got a ScanGauge “hard wired” in, so it’s not a question of monitoring. TechStream is a powerful tool that many people use on their more modern Toyota’s. Just trying to see if it’s compatible with the 96-97 FZJ80s and what can be done with it.
The seller kicked me version 028, but no luck. I’m guessing it’s a cable compatibility issue as I just get “unable to establish communication with the ECU”.
