update on suspension upgrade
Haiti
I've recently decided to install the Bilstein/Old Man Emu setup. I opted for the OME 861/862 springs, simply because I didn’t want my car to sit too high.
After about two months driving I realize the Bilsteins are a bit too stiff for my taste. I tried to play a little with the tire pressure to no avail. Tires are currently at 30psi all around. Going over bumpy roads is especially bad, and there are a lot of those where I live!
I'm beginning to wonder whether I got the right shocks, or whether some other components in the suspension is starting to fail. I'm thinking of doing a complete inspection of the suspension bushings just to be sure. Any other ideas? Should I revert to the OEM/Tokico shocks, which are known to be less stiff? I don’t do much off-roading so travel length would not be an issue for me.
I installed the OME 861/862 springs with the OME shocks all around last summer. Doesn't seem too stiff to me. I've driven interstate, backroads and dirt roads but nothing off-road so far.
If it makes any difference, I'm running brand new BFG 285-75R16 AT's.
changing the springs, or changing the shocks? That is the question!
I'm running OME 861/862s with new Toyota shocks from CDan. Not too stiff for us at all. Personally, I wouldn't put those old springs back on my truck.
Just to make sure: is it normal for the top of the front spring to be compressed as shown in this picture?
I installed the same OME 861 & 862 springs with the N73 & N74E shocks along with an SD24 Steering Damper and can't say enough good about the results. I am running an ARB with a 12k Warn winch but otherwise all is stock. Great improvement over the stock LX springs. Much better control and ride although firmer not objectable in the least.
After looking at the spring pic and seeing you're running a diesel engine I suspect you have too little spring for the diesel. I have quite a bit of clearance in the same coils where you have none.
Is it possible to install a spring upside down, or will it just not fit? Does it make any difference either way?
If those are OME's, no.
They are not progressive springs.
You either have spring failure, or way too much weight for those springs.
I installed the OME 861/862 springs with the N73/N74E shocks and SD24 steering damper and am very pleased with the results.
These are new Old Man Emu springs. What do you mean by failure?
I have done quite a lot of reading on these, and I've never seen any comment about them being unable to carry the diesel engine. I'm surprised and disappointed.:frown::bang:
That said, since there is a consensus on trying the OEM/Tokico shocks, I think I'm gonna do that, since they're not expensive. I'll let you guys know the results.
These are new Old Man Emu springs. What do you mean by failure? I have done quite a lot of reading on these, and I've never seen any comment about them being unable to carry the diesel engine. Hmmmmm. That is disappointing.
Like any other part, springs can fail. Basically either part or all of the spring will not hold the load it is supposed to, and you end up with what you show.
If it was spring failure, I would imagine that one side would look like what you posted and the other wouldn't, which would make it quite obvious. Since you didn't mention this, I'm assuming that both springs are doing it.
Slee rates the 861/862 as basically stock replacement springs, in other words not really designed for carrying much weight (Slee's site suggests 250 lbs max). I'm guessing that the diesel weighs more than 200 lbs more than the gasser.
It looks like you need to upgrade to the heavies. If you don't want them to be too tall, you could cut them down. Landtank recently had a thread about cutting down some springs to be the height he wanted.
I think your issue is those springs. No way are they supposed to sit like they are in your picture.
You also have to match your springs with your shocks. Don't go out and get OEM shocks without making sure they match up well with the OME springs you have. But like I said, I would try and figure out why your springs are sitting the way they are.
There is something wrong .. I'm running 850J and 863 in my HDJ80 with a front winch and rear bumper plus tire carrier and those are more stiff than factory but I love 'em ..
Keep in mind that suspension it's a matter of taste what will do fine for me not necesary do it for ya ..
Back to the coils point .. I never saw ( even with my soft Rancho coils ) that situation that you picture with your coil ..
Can you take a pic on how much space do you have between the lower part of the bump stop and the coil base bucket . ?
Last .. IMOP OME are better compared with those bilsteins .. 5110 or 7100 are another story. But would be nice check the valving numbers for those Bislteins ..
Is there any reason you didn't go with the OME shocks along with the springs? They are designed to be used together. I went with the OME shocks and springs last spring and I have had great results both on and offroad. I just took a trip with 4 guys, 4 bikes, a rooftop box and camping gear for a week and it was pretty loaded down, but still drove great, probably even better than when it's not loaded.
I use Bilsteins on my VW's but not my trucks. Too stiff. The lifetime warranty is nice though. I've replaced 3 for free on my Passat.
The shocks are not going to change the way that spring is sagging. I would contact OME and see what their recommendations are.
Newsflash - those aren't OME springs.
There are springs designed to sit exactly like what is in your picture, but not by OME.
You sure? The OP specifically stated OME's....
