also, sorry for the double post, but I realize this was all done on 60s. Is there any reason why this wouldn't work on a 62?
I just tried this last week. You cant get the 60 cernter thing to work on the tw35. You have to shave too much material@g-man and @klinetime574 thank y'all for putting this together. I bought the short harness first and then went back for the Ultra Power TW35 switch. Thanks for that. I'm curious @g-man if drilling holes at 9 and 3 o'clock worked... or if you would have stayed with the 3 pin oem 60 cylinder if you could make it loose enough to spin without squeaking!!? I haven't installed the Ultra Power TW35 switch yet.
Got it. Thank you. Swapping today. I’ll drill to two holesI just tried this last week. You cant get the 60 cernter thing to work on the tw35. You have to shave too much material
I drilled two holes in the back of the steering wheel and left the 2 pin signal cancel cylinder in place. Originally when I pulled it off which wasn't too easy and tried putting the brown original cylinder on the new switch I realized it was WAY to tight and would need a lot of sanding to fit. Drilling seemed easier. To mark the right spots on the back of the wheel you may try some colored grease on the two pins and centering things up just touch them to the back of the wheel.@g-man and @klinetime574 thank y'all for putting this together. I bought the short harness first and then went back for the Ultra Power TW35 switch. Thanks for that. I'm curious @g-man if drilling holes at 9 and 3 o'clock worked... or if you would have stayed with the 3 pin oem 60 cylinder if you could make it loose enough to spin without squeaking!!? I haven't installed the Ultra Power TW35 switch yet.
Thanks @g-man. It's installed! Works great. I will no longer be the annoying oblivious guy with a turn signal on for days. I will miss the intermittent windshield setting but I couldn't find anyone who had solved for that with these switches... oh well. I bought a switch a month ago but it had the short wiring harness. The seller returned my money and didn't want the harness back! Ha. The short harness went in, but kept me from raising the steering wheel enough. Nice to have that solved. I didn't know at the time of that first install, about the 3 vs 2 pin plastic column. This time I used a metal punch and marked the two holes on the steering wheel so the drill bit wouldn't squirm around. Removed all grease. Set up the shop vac to suck up metal shavings as I drilled the holes. Cleaned any remaining shavings then replaced the dielectric grease for the horn. I was able to salvage the wire clips from the original harness and it feels better to have everything properly secured. Thanks again for the tip about the TW35, the holes at 3 and 9o'clock, and the solder on the horn pin. The truck is currently in top shape.I drilled two holes in the back of the steering wheel and left the 2 pin signal cancel cylinder in place. Originally when I pulled it off which wasn't too easy and tried putting the brown original cylinder on the new switch I realized it was WAY to tight and would need a lot of sanding to fit. Drilling seemed easier. To mark the right spots on the back of the wheel you may try some colored grease on the two pins and centering things up just touch them to the back of the wheel.
Also see post #46 on pg 3. Make sure you swap out or put a decent terminal end on the green wire that goes to the horn pin. Makes no sense to just solder that wire. Mine broke after flexing several times and needed a proper fix.
I’ve got intermittent and cruise on mine.Thanks @g-man. It's installed! Works great. I will no longer be the annoying oblivious guy with a turn signal on for days. I will miss the intermittent windshield setting but I couldn't find anyone who had solved for that with these switches... oh well. I bought a switch a month ago but it had the short wiring harness. The seller returned my money and didn't want the harness back! Ha. The short harness went in, but kept me from raising the steering wheel enough. Nice to have that solved. I didn't know at the time of that first install, about the 3 vs 2 pin plastic column. This time I used a metal punch and marked the two holes on the steering wheel so the drill bit wouldn't squirm around. Removed all grease. Set up the shop vac to suck up metal shavings as I drilled the holes. Cleaned any remaining shavings then replaced the dielectric grease for the horn. I was able to salvage the wire clips from the original harness and it feels better to have everything properly secured. Thanks again for the tip about the TW35, the holes at 3 and 9o'clock, and the solder on the horn pin. The truck is currently in top shape.
forum.ih8mud.com
Lost, not list@dbbowen what does that mean? Intermittent and cruise? I have Mist, Low and High. List intermittent with the new switch
if you look online, you can get that same part for like $20this thread goes back several years , any opinion(s) about this after market part ? or cruiser corps the vendor ?
Headlight / Signal / Washer / Hazard FJ60, FJ62 8/1980 - 1990 - https://cruisercorps.com/products/fj62
used oem rare to locate & just as old as the cruiser in age .
marc
