Transmission Flush
OKC, OK
I was getting my oil changed this morning and the tech showed me my trans fluid color vs new trans fluid. Mine was rust brown color compaired to the pink/red of new fluid. Is this something that they can do? Any advise here would be appreciated...
Some say you can drain and refill, but you probably should not have it flushed.
Don't flush. Drain and replace several times (over a period of time). Too many instances of someone having their tranny flushed and then experiencing problems. IF you do 'flush', do it yourself...using the transmissions own pump. There are several threads on how to do that.
If you have your tranny commercially flushed the machine they use 'might' use more pressure than your old seals can take.
Draining and refilling doesn't get the fluid in the Torque Converter or what is left in the Valve Body, that is true enough, BUT by doing it at intervals, you eventually exchange good fluid for bad (as it mixes) and is replaced.
Our shop uses a BG trans fluid exchange machine. It isn't a flush, no added pressure. The new fluid simply pushes out the old fluid by using the trans own pressure. I use it on all my own high mileage vehicles and customers vehicles, never a issue. Pics from when i installed a external trans cooler and did a BG trans fluid exchange on my 02 4runner. You can watch the fluid change as the machine works, fluid before & after.
Do I just ask if they have a fluid exchange machine? Is BG the only company that makes these? How much do you charge? I would like to have this done by a shop, but I DO NOT want them to pressure flush it. I did it myself on my FJ62 years ago and while it wasn't hard, it was really time consuming and I am still not sure if I ever got all or even most of the old fluid out, even after about 5 drain and fills. It also seems like all you are doing is diluting the old fluid, but never really getting all the old stuff out.
I'd recommend the DIY option. Disconnect the hose from the transmission cooler and flush out a few quarts at a time (with the engine running). Pour the same amount of new fluid back in through dipstick. There's a writeup somewhere on how to do it but it will result in a complete fluid exchange once complete. A shop could also do this without any special machines.
Note that I haven't' done this yet on my FZJ80 (fluid is only a two years old) but did it previously on another vehicle (Volvo) and it worked really well. I used a 5 gallon bucket to flush into, before i started I marked the bucket with lines showing each quart. Its easier if you have a helper to turn the engine on and off while you handle the fluids.
Just google BG services in your area. Shops with their equipment should come up. With the BG machine it gets ALL the old fluid out, convertor, cooler, ect... We charge a little over $200 and that's with synthetic ATF.
I did the exchange on my 96 about a year ago. I found it shifted a bit better.
I used a 5 gallon bucket, 20 Quarts of trans fluid, a couple lengths of hose, and a new funnel. I got one of the "transmission funnels" with a lid and a hose and a shut off valve at the bottom. The one I got fit PERFECTLY into the coils of the brake lines on the master cylinder and I cut down the hose to drop perfectly into the trans dipstick tube. I had to start/stop the engine at least 3 times to do a refill. I also succeeded in making a HUGE oil mess in my driveway because when I was filling the trans, apparently, it would bubble out the top of the dipstick tube because I was pouring too fast.
I bought a NEW 5 gallon bucket, and measured out each quart in the side of the bucket and made a mark INSIDE the bucket with a number so I would know how many quarts I poured OUT, so I knew I should put back the same amount. (Measure the average diameter of the bucket, then the height and divide by 20 quarts. Every inch will be "xx' quarts.)
Lay down a big piece of plastic.
Drive the Cruiser onto the plastic.
Spread oil dry on the plastic, making a "moat" around the area that may see oil drips.
Remove the grille assembly.
Unhook the hoses from the trans oil cooler in front. (read the other thread so you know which one is suction and pressure)
Make sure you secure the hose in the bucket!!!!! Otherwise it will blow out and spray all over...not really spray, but it runs out fast.)
Set up the funnel in the dipstick tube.
Start the truck and watch it push out the fluid into the bucket.
Shut off the truck when you hear the pump sound of the transmission.
Refill based on the number of quarts that you have pushed out. (Usually 3-4 at a time)
When done, put the hoses back on the cooler where they came off.
Clean up the oil spilled
Drive it!
Double check the transmission oil level. Adjust as necessary.
See, this is part of the reason I don't want to do this again. I don't mind a drip here and there, but we shouldn't be creating our own Super Fund sites here. That stuff ends up in our water and I don't know about you, but where I live, we think about water all the time because we are worried that people like you are going to poison your water and then you are going to want to get your lips on ours.
Good containment and disposal regulations are a good thing in this case. The closest BG is in the Twin Cities, but I am thinking I might make a reason to go there and have them do it while I stare with gaping jaw at the big city.
For $200, I can barely buy 12 gallons of Farm & Barn ATF. I would rather have them do it and give them some of Jay's Silk Juice than fiddle f around in my driveway for three weekends. That's just me though...
For the interested, here's a really good video that explains why you would or would not want to flush or drain and refill your transmission fluid.
Seems to me it boils down to: if your fluid looks absolutely awful and you do a flush, and then your transmission has problems, it's because your transmission was failing anyway, as either the clutch material was suspended in the fluid and was the only reason your clutches are working, and since you flushed all the material out of the fluid, the clutches don't operate properly anymore, or you get gunk clogging up the passages in the transmission, stopping it from shifting properly.
Flush it yourself using the hoses attached to the cooler as others described. It's really easy and if you understand how to use a bucket you can avoid creating a "superfund site". Drain and refill wastes alot of fluid and takes forever.
FYI, system capacity is 12.6 quarts, not gallons. Just thought I would add this info for people that may stray into this thread and get the impression that they needed 48 quarts to service their tranny.
It can be done without making a crazy mess. Having a helper turn the engine on and off helps so you can focus on managing the bucket and funnel. Keep a close eye on the funnel to dipstick connection and don't go crazy with adding too much fluid at once.
An easy way to measure the bucket is to pour two quarts of water in and mark the bucket with a piece of duct tape (or a marker that wont rinse off) at each two quart interval (or one quart if you like). Pour the water out and you now have intervals of where to start and stop the engine.
Its quite satisfying to see all the old fluid come out and the bright red new fluid come through.
This was a really easy process as others have already said. In one of the threads someone suggested that the tranny would suck the fluid in as the old fluid was pushed out. I tried this with a bucket full of fresh fluid on the ground and it didnt work. I filled via the dip stick but was then told that the fresh fluid has to be higher up than the tranny to make it work.
Here's what I did:
China*Mart sells 1 gallon Valvoline Full Synthetic transmission fluid for ~$20 per gallon
When changing the motor oil and everything is dirty and truck is already on ramps.
Drain the transmission pan using your oil drain pan.
Oil out will be about 1 gallon, put into your used washer fluid or whatever bottle you use for oil to measure.
Fill using long neck funnel slowly or it just runs all over.
Put a piece of cardboard under your pan if worried.
I have been doing the "gallon out,gallon in" with each oil change and my fluid looks really good. Quick, easy, drain bucket is already under the rig.
Yep, that is how I maintain mine as well. I get just over a gallon of fluid per 'drain' (about 1.2 gallons). This regular regimen keeps fresh fluid in the tranny. Very easy to do .
Dont they have a drain plug on the trans pan my 92 does , i get about 8 quarts out of my trans pan
