Transmission Flush
See, this is part of the reason I don't want to do this again. I don't mind a drip here and there, but we shouldn't be creating our own Super Fund sites here. That stuff ends up in our water and I don't know about you, but where I live, we think about water all the time because we are worried that people like you are going to poison your water and then you are going to want to get your lips on ours.
Good containment and disposal regulations are a good thing in this case. The closest BG is in the Twin Cities, but I am thinking I might make a reason to go there and have them do it while I stare with gaping jaw at the big city.
For $200, I can barely buy 12 gallons of Farm & Barn ATF. I would rather have them do it and give them some of Jay's Silk Juice than fiddle f around in my driveway for three weekends. That's just me though...
Then don't do it.
It's not like I was letting the oil run on the ground and soak in. JFC.
I catch it in a bucket, what spills is soaked up by oil dry and taken to my work place where we have a disposal setup for that since it is a machine shop.
Then I go find one of those storm drains with the picture of a fish on it and pour the rest of the oil down the bottomless pit. I never do get it filled up, no matter how much oil and antifreeze I pour in there...........
#didyoumeanthecorolla
Top Ten Best Selling Cars of All Time
Car Sales
1. Toyota Corolla 37.5 Million
2. Ford F-series 35 Million
3. Volkswagen Golf 27.5 Million
4. Volkswagen Beetle 23.5 Million
Back to Trannys
Then don't do it.
I re-read what I wrote and I think I come across as a jerk. I shouldn't have taken the tone that I did and I apologize for that. I am happy to see that you share my concern though and it sounds like you have a good plan. I live a mile from Lake Superior and I do care about protecting that resource. I think I may have been a little buzzed when I wrote that and I had just watched my idiot neighbor dump a bunch of oil into a collection basin near our homes. I don't think he makes the connection that what he dumps there goes pretty much directly into the lake after being filtered by a bunch of rocks and soil that the city placed there.
I may consider doing this, but I might also just have it done.
At any rate, I am sorry for getting on your case. You have a lot of good advice on this forum and I don't want to miss out on any of it because you are salty with me. :)
No Worries!
Hey, I give it and I get it! Sometimes, the "flavor" of what you're intending doesn't come through in the written word! As you can tell by my later sarcastic post about my typical oil disposal........ No, I don't really do that. My son works at O'Reilly Auto, so it's REALLY easy for me to get oil recycled.
Stay warm up there!
Did the transmission fluid exchange today and didn't make too much of a mess. On the 94' the place to connect your clear 3/8'" drain hose is the top of the transmission cooler. Disconnect the black hose and connect your clear hose to the cooler.
I used an oil pastel (like a grease pen) to mark two quart intervals inside a 5 gallon bucket. Instead of guessing I literally filled the bucket with water at two quart intervals and marked it. The flow from the clear hose was nothing crazy and I could easily start the truck, let it run and walk back to shut it off at each two quart interval. The slowest/messiest part is refilling through the dipstick via small funnel/hose combo.
Valvoline Maxlife Synthetic ATF is currently only $18/gallon at Walmart. I used four gallons and it was flowing bright red when complete (last exchange was ~30k ago so the old fluid wasn't in bad shape).
An easy DIY for those wondering about it. A few key tips:
- Go for a drive to warm up the cruiser before starting (its not as hard on the warm engine when you keep starting and shutting it off)
- Store the new ATF inside a warm place the night before so its easier to pour
- Have a plan for safe disposal of 4 gallons of used ATF
- Pick up a 6' length of clear 3/8" hose
- I'd recommend using a fill funnel/hose combo with a shut off valve to make the filling process cleaner
- You could probably drain 3-4 quarts at a time but two was easy and the transmission never runs too low
- Remove the grille (easy) don't try to squeeze behind it
- Once you are done go for a test drive to warm things up before doing a final ATF level check (while the engine is running)
