Just a FYI adjusting the pressure regulator without doing the accumulator springs will definitely increase the harshness of the shift. If you're going to drop the pan, replace all the fluid, etc I would just spend the $99 and get the kit....
Tools is commenting on the hardness of the shift from L to 2nd when you are in low range. I didn't think with the kit it was that bad, but even when it was stock, when I was offroad, 8 out of 10 times when I was in low, I would use the 2nd gear start anyways. But when you need it, you just drop the transmission in L and it holds L, so the hard shift doesn't happen. I have found it to be a non issue. If you need the wheel speed you can start in 2nd or even shift into H. When you need the slow control you will want to be in L anyways. There might be a circumstance when it is noticeable but I am not sure what it would be?
time to revive this thread seeing how the turbo is out. what transmission does a 96 have. summit lists 3 different transmissions but I'm not sure which one to get... A340, 341 or 343
Should have been part of the turbo kitand here are the OEM components you'll need to complete the process along with the TransGo kit:
80 Series- 95-97 A343 Shift Kit Components
80 Series- 95-97 A343 Shift Kit Components (SKC-A343)absolute-wits-end.com
More seriously is the difference between the shift and reprogram kits that serious? I have a rather low mile trans that shifts firm already (or so i think) but was wondering how big the difference of shift was between the two kits. the base is just springs versus the drill out holes in the reprogram kit correct?
I just built my motor by myself and consider myself a fairly capable mechanic but some of the threads with open ended questions make me wonder how easy the instructions are to follow on this and the last thing i need is a buggered trans with this now being my DD.
94k now! Though i think it's overfilled which i need to address. I'm leaning towards that route but i do like the idea of the shift kit.If it is your DD, and it is a low mileage <100,000 mile transmission, just try the turbo kit without the shift kit. If you don't feel like it flares bad during shifts you don't need it now, but you might in 50,000 miles.
