Transfer case leaks
I drained and filled my transfer case today. It was low when I checked it yesterday (topped it off then) and since then it has been leaking from a small hole just above the parking brake adjustment bolt. I'm sure it didn't leak before because it was too low. Would it be fairly easy to fix this leak and can somebody tell me what seal I need to replace? Any special tools needed?
Would the seal I need be number 24 in this diagram? http://www.sor.com/sor/cat068.tam?xax=5716&page.ctx=cat068.tam
Thanks
Having just been through this, you may need to replace the seal (Napa 17754, National/ Timken 494122, Toyota 90311-45001).
If there is play in the output shaft/parking brake you must fix this first. There are round shims that go inside item 16 to set the bearing preload. Additionally you may have groves worn by the seal into the parking brake drum. These can be fixed by using a Speedi-Sleeve (Timken #KWK99177) and/or installing two seals. Marlin and Mudrak can machine item 16 to accept 2 seals for ~$30. I did this with a die grinder in 10 minutes.
All of this has been recently discussed so do a search and you will find everthing you need.
dgangle said:
Marlin and Mudrak can machine item 15 to accept 2 seals for ~$30. I did this with a die grinder in 10 minutes.
he means item 16. it's an excellent choice and will pretty much eliminate leaks from the worst grooved drums.
duh, 15 is the seal! 16 is the cast iron speedo housing. Thanks for clearing that up.
Ige, I did my first Speedy-Sleeve a couple weeks ago. I have heard that they are a temporary fix and wear through in a short time. What is your experience on this and did you find the driver/installation tool able to push the sleeve on far enough? I tried to press it on to work with both seals but the instal tool bottomed out and thus I was only able to press it on far enough for the original seal. Regardless, two new seals and a Speedy-Sleeve and leak fixed.
I already ordered the right seal for it last night. I guess when I get it apart I'll find out if it's grooved or not. I'll bookmark this page and refer to it if it needs more than just a seal. Thanks for everybody's help!
This site is great and I'm learning tons. Thank you all!
be thankful you don't have this leak
That looks like it came from the inside. Oh SH*T
it drove for 150 k's like that before succumbing to the dreaded no oil syndrome :)
so i don't know if it came from inside it was a non required part
i didn't even bother with the sppedi sleeve as the only fix...i went right to mudrak for the double lip seal...i do have drums with speedi sleeves that i installed, but am not running, no problems on installation.
a testimonial to the mudrak setup...the first one i bought never leaked out the back, but i had so many problems with the crap adapter and had dropped the t case so many times i managed to seriously chew up the outer seal, so i figured i'd replace it...chunks were missing from the outer seal and still didn't leak!
i have a serious pressurizing issue with my tranny (discovered at moab this year)...after the drive from moab to denver, barely dripped even though the tranny had pushed an extra quart or so into the xfer!
mudrak's double seals kick ass!! :cheers:
Trollhole said:
Can you see the hole? Note to self allways counts bolts before installing. This happened 5 min after installing the newly rebuit t-case.
:crybaby:
this would have never have happened had you uncrossed your speedo and ebrake cables :) - thats what screwed you ;)
