Transfer Case Leak | Please Educate
Bozeman
'84 FJ60 with Chevy LS and H55F swap.
Slow oil leak and pooling on ground when parked from T case.
It looks like it's coming from this wiring harness on top of the T case (see picture - zoom in close and you'll see a drop of oil starting to pool)
1) What does this wire lead to?
2) Is this a common leak point? Is it a bad washer or o-ring? Or something else?
Appreciate any help.
Those are range position sensors found on a lot of 88-newer cases (All USDM FJ62's and many 70 series). Are they actually plugged into anything on your 60? I see what looks like a twin stick shifter, someone must have replaced your transfer case's rear half at some point.
haha welp. @cruisermatt thanks for the confidence to pull the wire a bit and interesting to hear what that would be used for. Those indeed go nowhere on my setup (see 1st pic). And yes I've got a twin stick now (see 2nd pic)
I thought the same thing about being high up @FJ Silver 🤔 But I was able to get a small rotation with the vice grips (tough position). I'm hoping that does it 🤞
@PanhandleFJ i knowww. Fresh carwash but I promise she's seen some mud here in southern MT ;)
