Trans install - SO CLOSE
IDave said:
Steve, are you saying to put the pilot bearing on the input and then sliding it through the installed clutch plate? Or do you mean to trial fit it prior to assembling the clutch?
Now Dave.....what kind of question is that? :)
EDIT: Poser: "Are you serious?" LOL! Yeah, that's what I meant :D
Guess that I have had to use 180 on a lot of input shafts for a while over the years to make the pilot bearing slip onto the input shaft....so I do not even think twice about it, and it is simply part of the procedure.
:beer:
Pin_Head said:
The chances of the pilot bearing not fitting are slim to none.
i've see three that needed to be fitted...both of mine and a buddie's(which is now one of mine).
i don't think it's that uncommon.
besides a 3 second check could save a headache later.
Damn, I do NOT want to have to take everything off again to get to the bearing!
Pin_Head:
How would somone standing on the clutch help?
THANKS EVERYONE, I can feel it getting back on the road any day now as long as I keep up the progress.
DenverCruiser said:
Pin_Head: How would somone standing on the clutch help?
He is suggesting releasing the clamping force of the pressure plate, by depressing the clutch pedal, to allow the input of the transmission to align with the pilot bearing, as the vagueness of the plastic clutch alignment tool could have the disc not perfectly lined up with the pilot bearing, and you could be fighting the clutch disc.
If this does not cure it, you will need to take everyting apart, remove the pilot bearing and fit it to the input shaft....
I would not draw the tranny up the rest of the way with bolts, as I have sold flywheel housings to people that have done this. ;)
Good luck!
-Steve
pushing on the clutch pedel hope you have your slave cylinder and clutch fork in place, it disengage and takes pressure off the disc in case there is a binding issue with the in put shaft will allow to move a little . same as just like loosning the clutch cover as so the disc can move.
if you con not git the bolts to line up becouse you are hitting the floor you have a way's to go you might want to back it out and start over. I've had to do that too...
I do not want to sound like a smart ass,..but did you remove the tranny cover ?
Just had to ask ....:cheers: Good Luck JC
Not taking any questions as smart ass! Definitly went one banana too far with this project and really appreciate your guys help. And yes the trany cover is removed.;p
Looks like tomorrow I am going to hook up the clutch slave to the fork and see if that works. I really don't want to remove everything but if that is what it takes well see.
Poser said:
Are you serious?
Hey, I've not done this in a while, and didn't look at the diagrams. What can I say Steve, your instructions are sometimes vague to the uninitiated.....:o :D
Its how you learn ! the first one's a PITA been there 'my first clutch on my 71 40 took me a week and ruined two pilot bearing :frown: last one about 4 hours I also used apair of long 12 " tapered drifts as guides in the top bolt holes through the trannny as a guide, untill you can git the bottom bolt's in then the top ,bolt's measure and make sure your are parallel then wiggel and go easy tighting up the bolts real easy it should go.... I've only had help doing a clutch once and we put the disc in backwards :doh: JC
my thoughts exactly , sometimes it is slightly missaligned , push the clutch and in she goes . i to usually check that the pilot bearing fits the input shaft before installing it into the crank
Pin_Head said:
No big deal.
Plastic clutch alignment tools suck.
Have someone step on the clutch while you wiggle the tranny and it will slide right in.
Is the tranny cover out? When I did mine, the shifter hole was getting caught on one of the nuts that is welded to the cover. I only noticed when I got up in the truck to check. Good luck.
Try taking 1.5 years to get it done!:eek: :eek:
I may be stupid for typing this but here goes. if the pilot bearing is properly seated and the disc aligned fairly well in the clutch package, take out the tranny hump use compression type straps between the frame rails to hold it steady and have someone in the truck helping you support and "wiggle" the damn thing. I always put a tranny in low gear and then when close and loosely bolted spin the output, or if your doing it with the transfer (I would) spin the ebrake drum. the splines will catch and line up. That should do it. I can't think of any thing else that would prevent this from bolting up unless that clutch disc is way out. Also you could have your man topside push in the clutch a wee bit if the slave is operational. Good luck these projects are always so much fun!
Good advice, but I think he is lacking only 1/2" or less, according to his posts. That would mean he is hanging on the pilot.
And it is easier to spin everything with the tranny in high, not low, IIRC.;)
Ed
poser:"I would not draw the tranny up the rest of the way with bolts, as I have sold flywheel housings to people that have done this"
It does take having a feel, or touch, and shouldn't be attempted by neanderthals with more brawn than brain.
I guess I should have mentioned those qualifiers. :)
