Trans install - SO CLOSE
Woodstock, GA
OK trying to get the trans back into the cruiser yesturday. Was able to get the splines alined etc but when pushing in there is still possibly 1/2 inch to go between the bellhousing and trans bold holes. I have tried wiggleing it etc to get it the rest with no luck. Any tricks here? Do something wrong? Thanks guys and Happy Easter.
Sounds like the tranny input shaft has not found the pilot bearing yet. Be gentle, you don't want to damage the pilot bearing. You probably have to lift the rear end of the tranny/tcase as you wiggle it into position.
Just my experience.
Did you use a clutch alignment tool? The one that goes through the clutch plate and into the pilot bearing and is left in place while you tighten the pressure plate down. The clutch plate can move significantly side to side and up and down. If you didn't use an alignment tool you'll have a hard time to align everything.
put a ratchet strap along the tranny (under the transmission and over the frame-rails and ratchet it till its tight) that should take the weight off it and you should be able slide it in better.
Even after using an alignment tool it's possible to move the disc slightly when you're trying to muscle the trans. around to make it drop into place. Worst case would be having to go back and loosen the clutch plate and start again with the allignment tool.
Does your alignment tool fit tight? Those plastic POS ones aren't great. If you have an old input shaft that's maybe the best. I've got some that I turn on the lathe for each type of use.
I like to use longer bolts in a couple of the mounting holes to line up the trans and pull it down into the pilot gently. Once it seats put original bolts in the remaining holes, remove the longer 'guide' bolts, and torque it down.
brian said:
before installing the pilot in the crank, did you try the fit on the input shaft?
No... I wish I had. The alignment tool still fits perfectly so I don't believe the clutch is in the way. Going out now to try again. Going to go compare the diameter of the alingnment tool compared to the shaft right now.
CruisinGA said:
use a tape measure or ruler to check all the way around the mounting surfaces to be sure the distance is uniform before trying to insert the transmission.
Done this the last clutch job .;) Then turned the bolts real easy not to push out the pilot bearing it should pop in .Also if before you install pilot bering pollish it and the input shaft with some emmery clouth as remove any burrs and the bering slips on and off real easy. then I use anti-seaze on input... just an Idea ? JC :cheers:
peesalot said:
Does the bell housing have a inspection cover like the gm ones ? if so , loosen pressure plate , fit tranny , then tighten.
Inspection cover? What does that look like? :confused: :confused: Just tried it all again with no more luck. Splines and all go in easy. Exactly 1/4" left. It does NOT seem to want to go into the bearing. I cant put the bolts in to help tighten because at 1/4" back there is not enough room under the floor to make it level to line up the bolts either.
one good trick is to get 2 extra long bolts, cut the heads off and put them on either side of the bellhousing. You can use them as guides to get things in, then take 'em out and use the real things to finish up.
Simular to the suggestion of anti seize, I always put a small smear of grease on the pilot bearing to accept the input shaft...no pum intended.
Jerry D.
This is your issue.....the pilot bearing MUST be fitted to the input shaft prior to installing it into the crank, or this very thing will happen....
Steve, are you saying to put the pilot bearing on the input and then sliding it through the installed clutch plate? Or do you mean to trial fit it prior to assembling the clutch?
