Jon that was my question above. What unit would one need to run both ham and GMRS? Will I need one or two antennas?
The least expensive way to do both is with the Baofeng. It can do both right out of the box.Jon that was my question above. What unit would one need to run both ham and GMRS? Will I need one or two antennas?
How easy would it be to use the beofung with a hard mount antenna?
What dual band radio would you recommend? Not too worried about cost as long as it works well.
This is going to be a bit of a dissertation, so please bear with me. I'm a little hung over and only 1 cup of coffee down.How easy would it be to use the beofung with a hard mount antenna?
You may be willing to break the rules, but your radio may not let you. The major manufacturers of amateur radio will stick to FCC guidelines regardless of what you want. You need to research the frequency limitations of the radios you are interested in. This is all available on the internets.Jon - thanks for your answer. FWIW, I am planning to get Ham license and GMRS license. I am willing to break the rules and transit GMRS on my Ham radio as long as I know I am doing no harm. Sort of like doing 70mph in a 65 speed limit zone.
I am looking for a mobile unit (i.e. one to mount in the truck) with a single antenna that will do everything. Is that possible? Maybe I need to do more research to figure it out, but I was hoping someone who was already an expert would send me a link to an amazon cart!
I have the Beofung handheld and am not interested in trying to jerry rig it into a better solution with permanent power wiring and antenna connection. I'd prefer to have something designed for the task. I personally don't care how much it costs, within reason (say <$500 all in), because I want to have a hard mount, permanent solution that can RX and TX over long range. I am tired of being the guy who isn't sure if anyone heard me and not sure if I heard everything being said!
That's pretty cool. A simple solution. You'll need a BNC F to SMA F adapter to mate with the Baofeng SMA M antenna mount. Reverse that for the other end to mate with the antenna or get a BNC to NMO mount. All doable for a few sheckles.This is a viable solution for a handheld unit. It hangs over top of the glass of your window then you roll up your window and it locks it in.
One could use the radio's antenna on this mount, or get a longer, better rubber duck antenna for it. The end of the cable simply connects to the antenna BNC connector on top of your radio.
OPEK AM-801 - Window Antenna Mount - BNC Connectors
FWIW, after reading your chart I looked up the specs of my V71A. I can RX the FRS/GMRS frequencies, but my TX tops out at 450 MHz. FRS/GMRS starts at 462.5+. I don't know what other radios are capable of.Some additional info:
- All transmitters (with a few exceptions) except Amateur radio transmitters must be Type Accepted by the FCC. The FCC is to transmitters as the NTSB is to vehicles. Even your microwave oven (2.4 GHz transmitter in a metal box) is FCC Type Accepted. The FCC doesn't care about receivers other than they can't be tuned to cell phone freqs.
- Amateur radio operators can build and operate transmitters in the Amateur (ham) bands. The transmitter is not required to be Type Accepted but it must meet FCC requirements for frequency stability, transmit power, modulation, etc.
- Manufactured radios (Icom, Kenwood, etc.) for use in the ham bands are not Type Accepted by the FCC. As ham radios they don't need to be Type Accepted. It costs the manufacturer $$$$ to get a radio Type Accepted by the FCC.
- If the radio operator can change the transmit frequencies, via the front panel on the radio, the radio can not be Type Accepted. The FCC doesn't want the bored cop/fireman/bus driver to be able to change the transmit freqs on their radio. Type Accepted radios can only have their frequencies (channels) changed via an external computer & software.
- A modified ham radio that is capable of transmitting outside of the ham bands it not Type Accepted, therefore it is illegal to transmit a ham radio outside of the ham bands - with the exception of MARS (Military Auxiliary Radio System) and CAP (Civil Air Patrol) freqs when needed to support their activities.
- If you want a cure for insomnia, read the FCC rules & regs.
- The FCC enforcement bureau is primarily concerned with serious interference/denial of service situations to important radio communications infrastructures - like the idiot who transmits hate messages on police freqs. Or, the arcing insulator on a high voltage power line that is creating lots or RF noise and disabling a near by cell site.
- If someone is in the middle of nowhere using a modified ham radio to transmit on a GMRS freq, is the FCC going to dispatch their enforcement agents? Probably not.
- Sorry if this info is a bummer.
Nope. I have never nedeed GMRS frequencies. I'll just use one of my Baofungs if I ever need to play with that.There are two mods. Option 1 stops at 450. Do option 2 to expand to 470.
ICanWorkThisThing.com
Google v71a mod. There are YouTube videos as well.
Hope you have a magnifying glass.
