Toyota OEM Spring Options and Specifications
I used two of the 4813160D60 coils. Everything went in as it should and performs as it should. With the 10mm spacer the truck has settled at 20 inches hub-to-fender.
I did the math on the weight, and I arrived at 450ft/lbs for spring rate. I don’t believe that to be accurate. I believe it still to be 500ft/lb.
Thanks! What was your hub to fender with the stock springs (and with/without spacer)?
500 lb/in seems lower than expected. Is that the actual spring rate or the effective rate at the wheel?
Best,
Ken
Stock URJ200 is 500#/in for the fronts
Oh…do you think the diesel/winch springs have the same rate as the gas version but just a longer free length for more preload? I would have expected a higher rate.
I would have expected a higher rate as well. Just reporting what I had learned while going through the process of choosing suspension for my rig.
