Topless - finally!
what shackles you runnin
Trollhole said:
Crazy articulation. And great on the road.
I can raise the bumper off the ground almost 18 inches before the tires come off the ground.
just curious.
love your rig to :cool:
drove the 40 to work today,time to take the hard doors off,and put on my new 1/2 doors............ :bounce: :bounce:
more than topless
Yup me too the top came off today :-)
I am in the process of doing a partial resto..as you can see
everytnhing behind the diamond plate is rotten , the whole thing is rotten
I just pulled the top of last weekend. AHHHHHHH FREEDOM!
the 68's basically topless yearround now with the paki top, but i had to deal with the "peel the top off, break it into pieces and cram it in the apartment" issue before...not bad unless you get the crazy colorado weather. iirc, it was about 75 the day before.
Hard Top Hoist
Here's a few pics of mine. Finished it a few months back. Had a friend weld up the frame, used a HF 880lb electric hoist that I got pretty cheap. Mounted on scrap 2" square tube and some 2x12s to push the hoist up in the ceiling for clearance.
And before you fawkers blast me for the curtains in the garage, they're from the PO, I just never took them down. Work great to keep it cool in the summer and I can open the sliding doors for cross ventilation.
I guess i'm pretty lucky here, have not put the hard top back together in about 10 years. Just do not need it down here in NC, or GA. I guess it helps i've been over in the sandboxes the past 3 winters.
I'll send a few more to you PabloCruise, but for everyone on a budget I cut a 2x4 into 2 two foot sections. I then lag bolted it to the ceiling joist and used a 230lb eye hole screw thingy and screwed that in the center of the 2x4. I did this on both sides of the cruiser. I backed the cruiser into the garage and then used a block and tackle on each side to lift the top 8 or 9 inches off. I then pulled the cruiser out and used ratcheting tie down to pull it up all the way to the ceiling. :)
