Too much chain
Kansastitty
Decided to get off my a$$ today and accomplish something. Waited all morning for the son to show up, then decided to get to work. Since I figured I would be doing this myself, I got one of those leveling bridles....seemed like a good idea at the time.
At the limit of the picker, I still was not clearing the bib hinge. Fortunately that's all I lacked. Not the kinda thing you can just set down and shorted the chain. It is now sitting on a block of styrofoam I talked about in a different thread.
Guess this is not really tech, maybe a couple of greasy pictures will help.
Ed
Ed,
Remove the chain & hook from the cherry picker. Use a small bow shackle on the crossbolt of the picker. hang the leveler from the small shackle.
I have that same chinese hoist (w/ less paint and more race stickers) and that's how I've been doing it for years.
FJ40Jim said:
Ed,
Jim, I will definitely shorten something to give a little more margin before swinging the new motor back in. Good call on the shackle.
Thanks,
Ed
chewy said:
Let the air outta the tires.
Or extend the boom.
Letting the air out of the tires was next, but extending the boom was not an option unless I could set it down. And maybe I could have set the block of styrofoam between the frame rails and in fact, set it down. Both good suggestions.
I hate "whoops!" and "Oh s***" when using lifting devices.:D
Ed
Ed
"oops" are nothing.
"whoops" are'nt bad.
"oh s***s" can get expensive......quick.
brian said:
"oops" are nothing.
My biggest concern is that any of them can cause a "hurt":D
Ed
Yeah, I'd a let the air out of the tires at that point, or taken them off :D.
Well, there you go. Do you want the cast aluminum valve cover? The waterpump is about 5K old. I'm bringing you a boatload of old shiet.:D
Ed
Sure!
IDave said:
I just didn't know what level of "keep it original" you were.;)
I also found some more column shift stuff when eviscerating it:D .
Ed
Hmmm! I thought you sent it all!
Pin_Head said:
I think that we are going to have to put you on a short chain because the stuff you are pulling out looks better than the stuff I am running.
:flipoff2:
Actually, it is a good motor. Compression is 120+- across the board, except #5 which is 90psi. No change on a wet test, so probably a valve? Did not know it was a problem by the way it runs/ran. Smooth idle down to 550 and good power. This project is more about personal progress than common sense and mechanical know-how. I want an "intimate relationship" with every nut and bolt on the damn thing.
Just glad I used a day off properly:bounce: :bounce2:
Shoulda seen the chain-thing coming:doh:
Ed
this is a CLASSIC :D
Claudia, has anyone ever told you that you "do those genes justice?":D
Ed
Ed
I am not so sure what the genes think about that :D
Did I say "genes?" Well I meant Jeans:cool:
ed,
nice project you got going there....and i thought the power steering project i am getting ready to strart was a big deal....you make my project look like small potatoes...a dentist doing an engine swap...how cool.
osagecruiser
osagecruiser said:
ed,
osagecruiser
You should see him using dental picks to clean the ring grooves of his pistons.
