Todays wrenching
Fixing trailer before FG.
No. You need to use the donor trans depending on what donor vehicle you use. The 80 Series transfer case will bolt up to the 4 speed versions, but I don't think you can use it with the 5 speed version. Most of the 2UZ trans are a version of the A340. The A700 4 Speed Version from the landcruiser will allow you to use the 80 series TC. My donor was an 02 Sequoia so I my Trans is the A340, I then used and Advanced Adapter to mate it to an Atlas 4 speed.
Does fzj 80 transmission bolts right up to 4.7 v8?
Have to use a transmission out of a LC/LX for the transfer case to bolt up. Different output shaft and adapter housing than the other variants. I’m running a later 2uz with VVTi and the A750 5 speed. The VVT engine puts out a little more power and the A750 has a lower first gear, 3.52, over the A343, 2.80. Figured while it was out I’d reseal it since it was going to be half apart for the timing belt anyways.
