Tire weight
35" to 37" you'll notice .. are you re geared .? that makes a lot of difference with weight and leverage in " big " tires ..
With much heavier tires, you will notice a decrease in acceleration due to the increased rotating mass. The braking will also be impacted for the same reason. Both acceleration as well as braking will be negatively impacted by going to 37's.
You will also notice a difference in ride because the UNsprung weight has increased and you will feel more of the bumps and holes since the UNsprung mass causes more load to be transferred.
I specifically chose duratrac's over MTR's (need/want) because of the weight. Frankly for 80% of people's uses duratracs are just fine. I guess I would validate the "need" for 37's over the want. lol.
4.88 regear a few years ago. Along with cooling mods and SC
That was my setup with 315s when I bought it. Now I run 37s. Would NOT go back to smaller tires. Yes it weighs more and yes it is worth it, to me. Puts speedo dead on accurate.
I think my tire weight went up about 20# each. John
I run 37" double beadlocks on my Tacoma that weigh north of 150 pounds per corner. I did not notice a loss of acceleration or stopping power, regeared to 4.88. I think everyone gets hung up on the weight, but the truth is it just doesn't matter that much if you have the gearing to match.
BFG KM2 37=78LB with 5.29s . There Is a noticeable difference, no problem at all. 4.88 are great, I am off 12% at 60 MPG, at 50 I show 56. Thats the only Item I dont like. Good Luck.!
