tire balancing
Los Angeles
Guys, any of you have any experience with the various tire balancing methods? These Toyos seem to go out of balance pretty easily, and I know there are several products on the market that you can put inside to dynamically balance them. Dyna Beads is one, and I've heard some folks have used Airsoft pellets and BB's.
Anyone know what is the best deal out there?
thanks
Dana
Go to a shop that uses a Hunter GSP9700 for a good dynamic balance.
Dynabeads.
I will be posting up my experiences this week.
believe it or not, I actually did that. They were very nice for awhile, but gradually I can feel the shimmy creeping back in.
some background: ALL suspension bushings brand new, shocks new, alignment checked on a state-of-the-art hunter alignment system, found to be all within specs. New wheel bearings, all other bearings are fine. TRE and all joints good.
So it's definitely the tires going out of balance.
Dynabeads balance the tire throughout it's entire lifetime. As long as you get the amount of beads correct, you'll never have to worry about them again.
I went with Airsoft pellets. Had them put in 3 oz per tire, which isn't enough for my 35's.
It's almost enough, it's very smooth up until about 75 mph (except for a vibration at about 45 mph). There's a very slight wobble but I suspect something's a bit loose in my front end after my last wheeling trip. I'm blaming that and caster (yeah, I'm not corrected yet, sitting at about -1.5*) for the wobble.
Airsoft pellets will do the same thing as Dynabeads....at a fraction the cost. ;)
It's almost enough, it's very smooth up until about 75 mph. There's a very slight wobble but I suspect something's a bit loose in my front end after my last wheeling trip. I'm blaming that and caster (yeah, I'm not corrected yet, sitting at about -1.5*) for the wobble.
I bought cheap airsoft pellets. Concept is the same, beads are a little larger.
3oz per tire? The dynabead website lists 10 for 36x13.50's, so why so little for 35's?
Several reasons.
I think it was landtank who was running 10 oz in his 35's and found them to be way too much. He ended up at 5 oz and is happy with them now.
The "formula" I've seen is roughly 1 oz for every 15 lbs of tire. I say roughly because I believe that every brand of tire will be different, so even two tires that weigh the exact same won't need the same amount of beads.
So that formula gives me about 5 oz for my tires..... This also matches up with a lot of anecdotal evidence I've seen from other people posting both here on MUD and many other forums.
So why only 3 oz for mine? Three main reasons.
1) A few wheeling trips ago I stripped all of the weights off one of my tires. Aside from a very small vibe at ~55 mph, there was zero problems running it completely weightless. My wife's 31" Toyo M/T's (which are balanced with the inside wheel weights, which are supposed to be even better than the rim weights) have more vibes.
2) Not running enough weight will leave you with vibes, possible nasty wobbles at high speeds. Running too much weight can cause nasty death wobbles on braking (especially hard/panic stops).
3) I only had enough pellets on me for 3 oz per tire (it was a last minute decision :p ).
The heavier the tire the more weight you need. The more unbalanced the tire, the more weight you need. I could probably drive my Grabbers totally weightless and be okay. I figured I could drive with a slight vibe if I had too little weight and live with it....I wouldn't want to drive with a death wobble.
If I had Toyo M/T's (for example) I would have started at 5 oz and gone up from there. But I knew my tires were (relatively) light and true, and so started from the lower number. In retrospect, I should have done the 5 oz and call it good.
Tried the Dyna Beads with my TOyo 35's and ended up removing them in a week. IMHO the best thing to do is get you weight's glued on so the Rocks don't knock them off then all is well. Also don't forget to rotate often and be sure to have a little toe in on the alignment. Most shops will go to zero and you need some toe in to keep it straight.
Enlighten me,whats the thought here? Thanks, Mike
This is the easiest way to explain it: How It Works
Several reasons.
That makes a lot of sense! The tires I've got now don't vibe that bad until about 60, so maybe I'll cut down the weight to 7 oz or so. Thanks for the tips!
I used lead shot. 95% of the time it worked fine. On some occasion though the shot would get stuck and I would have severe vibration until I came to a stop and started again which unstuck the shot. I spoke to a large offroad shop here, and they said they run into the same issue with beads.
My old BFG KM1s and KM2s balanced with airsoft BBs. Then I went to 35s and some Kenda Klever MTs. First set balanced okay with BBs. Second set never balanced with BBs and I chased down a bunch of other random issues until I decided to take them to the tire shop and spend $90 to have them balanced in a tradition way. Instantly the ride was smooth as glass. I won't be going back to BBs as it seems kind of hit and miss depending on the tires and if the BBs will end up getting into the right places.
