Tips on installing a H55F into a 40?
I have a used H55F trans, sitting in my garade collecting dust...about time I put it in my 1974 FJ40. Any help ...helpfull
mahalo....thanks
If I had one in my garage it would be red hot from the friction created when I drug it over to put it in. You should be ashamed of yourself! Put it in or ship it to me to be put out of your misery!
mahalo....thanks
Oh my, oh my. I just did this to my 1969 FJ40 and suspect your install will be about the same.
1. You will need a split transfer case to go along with the H55F
2. You will need a body lift. I have a 1 inch. I was told it was to clear the body from the rear of the tc, but it actually was to clear the passanger side of the split case. It's still very close.
3. You will need to remove the frame crossmember behind the tc. This combo is long. I installed a new one further back.
4. You might need to modify your doghouse. On mine, even with the 1 inch body lift, I don't have enough clearance on the top of the shifter housing. I've already cut a 5" hole (same size as the shifter boot) and it still doesn't clear. Some fabrication will be needed to raise up the middle of the doghouse. I don't know if a tranny tunnel from a later model will work.
5. You will need to retrofit the parking brake to the back of the split case. There are kits out there from several vendors. I did not go with the SOR kit, and I wish I had.
6. I haven't gotten to the point of even trying to see if the parking brake cable will hook up yet with this longer setup. I believe BTB Products carries a longer cable, and they are very proud of it ($$$).
7. You need a 4-speed bellhousing.
8. You will need to modify your drivelines.
9. pic here: http://ratstew.home.comcast.net/trannytc.jpg
Good luck. Jon
What I would do if I happend to have a used H55 just taking up space is buy a later model (I believe '79 and up) rear end.
THey use 60 style brakes and the parking brake is done at the rear wheels! Saves you a few inches of driveline length...
They charge bucks for those e-brake kits...
i think you should trade it for a couple of H42 4spds and belhouseing, wich i just happen to have. (LOL) oh well, anyway i just thought i would tell you after you search the tec section that if you needed any extra stuff for the install that this is the weekend for the big 4x4 swap meet at the puyallip fair grounds, it only happens once a year, and its this sunday. its $5.00 to get in, but there is usually cruiser stuff there, mostly heep stuff but if you want to go power steering or anything the gear boxes can be had for around $15.00 to $20.00 + or - lots of stuff, its huge. good luck!!
