- Joined
- Jan 20, 2015
- Threads
- 9
- Messages
- 63
I have a lot invested into the FJ60 front end on my FJ40 and I dont really want to change it out to the 80 front, even if it would net me a high pinion third. I've just recently centered a 80 elocker rear end and put it in the 40 and it's great! So, I've heard someone say that you can run a rear 9.5 elocker third in your front exle assy.
If I understand this correctly, it looks like I'd need a custom axle made to get the longer splines for the elocker. Then just a little grinding at the diff opening and another 12 Volt Guy harness and bingo! Right?
If I'm wrapping my little brain around this correctly, I'd be running on the back side of the ring and pinion gears..?
Thoughts on this? I've seen a guy on here who is running this setup but I didn't see much of a writeup on it. Is it strong enough running "backwards"??
Apologies if this is a dead horse.. I have done SOME searching on this, but I didn't turn up much on the strength of running on the back side of the R&P..
I have a 350 (5.3 coming soon) SM420 and 37's.
Thanks for any input! Cheers!
on the SM420. Underrated great swap in FJ40s.
