Those running OEM Full-float axles...
OTOH, using 80 hubs on the rear would let those custom double-splined axles be shared by anyone using a 60FF rear housing, so that might be more practical...I can just see this thread driving up the price of 80 FF wheel hubs ;-)
Steve
Steve
The way I look at is is this: 80 hubs are not very common and probably are already expensive. You already have 60 FF hubs, why not consider some double studded spacers for the back to widen the stance (bearing loads are moot as 80 rears place their WMS as far out and use the same bearings) and put a rotor on the back of the hub like mustardfj40 did and fabricate a bracket for a cruiser caliper? Use a 1st generation Supra caliper if you need a parking brake. Adapting 80 parking brakes to a drum FF will already involve fabricating and welding anyway.
Dave
Dave...the answer is I already have the 60 axle (complete with bling cable locker), and none of this had occurred to me prior to acquiring it. so are 80 axleshafts longer than 60 (I must assume they are, that the extras width isn't just the WMS difference on the hubs)? looking at Tippy(pre)R at Moab, Peter's 80 axle looked borderline too wide to me...his 11" wide 11.00R16 XL's were stuffed right to the edge of the wheelwell, and I didn't really look to see if he'd modified the inner part of the wheelwell .
so, actually, the answer to your question could be "maybe". I'm actually curious about all this stuff, and asking the dumb questions in public, for all the folks who already have the 60FF housing...pretty sure cruiseroutfit's got several trucks in his group who have them/are getting them.
Steve
gotta agree that your spacer solution's a valid one, just want to know if the hub swap method is viable. I think I know the answer to that question now :doh:
I don't like sliding-pillar calipers, if that's the way the Supra calipers are made. I'm an opposed-piston bigot :flipoff2: Put 92 V6 4Runner calipers up front and move your 60 calipers to the back, ebrake on the tcase.
I am so web-wheeling right now!
Steve
This has gotta be one of the best conversations on this. If nothing else, it is informative and difinitive. I like it! Anyway, I too see your point on the wheel spacers, but I for one refuse to run them. I actually was running them on all four corners and one of them worked loose and wobbled all over the place. Took out three wheel studs and killed the spacer. It was on the rear and I thank my lucky stars that the wheel didn't come off nor anything happen to my precious hub... :D Ya, it was probably not tightened on well enough, but that's a risk that I don't want to even have to deal with again. So I went to custom backspace wheels for a wider stance. But the thing that happens a lot is that the caliper contacts the inner wheel surface. I guess I haven't actually tried the BJ on roids way nor any other way on the rear, so I can't say for sure if that would even be an issue for me, but i know it is an issue on the front. Ya, you can grind the caliper a bit, or grind the wheel a bit.... But it would be nice to have the option of not doing that and just swapping out front and rear hubs. Give a bit wider stance and get the WMS away from the caliper. Ya, it seems like it would take a bit more money, but I think it could be a nice option for the non-financially challenged.
Also, as for the 80 series rear. There's a guy on this board that's runnin' an 80 series rear under his 62 (username is FJ6202840). Check it out in this thread: https://forum.ih8mud.com/showthread.php?t=22645. I'm not sure exactly what he's doin' to compensate for the extra width. I believe his rims have some pretty deep B.S.
-Ferg-
Aww c'mon, Steve, even Toyota puts sliding ones (the formal term is "floating calipers") on factory Landcruiser FF rears :)
Dave
Overlord said:
Do you have a pic of the drive plates?
Finally took a picture of the early (fine-spline) drive plates...
