theferg said:Perhaps with 6 excellent studs (8mm, no rust), and four pins instead of two, it might last a while longer... I too like the idea of a fuse, just would hate to be drill out that s*** on the trail... 'Course I don't wheel much now do I...![]()
The problem is if you put 4 dowel pins, would the fuse still be in the studs?
I carry a spare hub as a spare carrier, complete with bearings and studs just so I don't have to fix broken hub studs. It makes sense to me since I am running the same hub and rotor on all 4 corners. A front hub apparently can be run on a factory FF, like what Brett G. is doing.
Dave
