fzj80 rear elocker in front fj62 diff
newport RI
Hi first off I am new at this type of forum so if this has been covered I apologize but if you would point me in the right direction i would be appreciative.
I am looking for a parts list for putting a fzj80 rear elocker in my front fj62 diff.
I know i can get the elockered diff from Toyota and I know I need a new axle shaft but where does one get the new axle shaft?
I attached a few pics of my fj62 from a trail ride this past weekend. The list of things I have modified on my cruiser is long and so is the list of things yet to do. But a short list of some of the bigger upgrades are as fallows:
Fzj80 complete rear axle (ff, elocker db)
OME heavies all around with Bilstein shocks
Custom foxfab protection at every corner
4.88 gearing
16x8 widened old style hub capped wheels
285r16 BFG MT’s
warn m12000
McNamara gear
Bunches of other stuff as well
Thanks for any and all help
Jason
I was reading through his web site. he spelled it all out pretty clearly and has part numbers and descriptions of everything I was looking for. great resource. right now i am in the planning phase i am sure i will have some question for theferg once i get started :doh:
Jason
I bought my inner axle shaft from CV Unlimited. $200.
sorry the shot I posted was taken in the pooring rain. here are some poser shots I took afterI added the rear ladder on the bumper. the wheels are fj40/55 steel hub capped wheels that I had widened. I wanted steel wheels and I like the retro look
Jason
Oh, sweet Cruiser BTW! I like the wheels and hubcaps--it's a great look for a 62 for sure. I saw a couple pics on pirate that were from the Gear Bash or something like that? There was a glimpse of your bumper and the ladder and I wanted to see more of it. I like it a lot. Not, to change the subject, but I heard it was a modified Cherokee rear bumper? I'm interested in some good close-ups of the swingouts if you've got any more...
Anyway, there's a buncha places to get the axle. But, might I suggest checking out this link to an eBay auction... ;) (not mine, just saw it on there. the guy posted in the for sale section here on mud actually...) eBay Item #2489674917 . I was thinking about pickin' it up for a spare for me, but I don't have ANY money to spare at this time. And i still have stock birfs anyway so i'll probably blow those before I blow an inner. HTH.
And if Dave's right on the price for CV Unltd, that's a killer price there as well.
EDIT: Now that I'm re-reading your first post about your rig and I saw your name, I'm thinking we've emailed a couple times before a few years back. Is this your rig in these pics? http://www.yankeetoys.org/black900rr/jasons62/rearaxle/ FYI, I have this link on my links page of my write-up... :D And the rig is lookin' SWEET!
May I ask how you are operating your rear e-locker? Still electric? Did you use the stock 80 series switch or...? I just finally got all the components for my relay/control unit and will be trying to get it going when I have some time this weekend...
-Ferg-
theferg
yep that is my fj62. that seems so long ago.
here is a link to a folder of the ladder build-up pics. I got the bumper for my dad, to see If I could interest him in 4 wheeling. it is a Tomken bumper and what i like about it is that the ends are bent forward 15 degrees or so so it doesn't stick out at the corners like a 2x6 channel would.
http://www.yankeetoys.org/cruiserjason/images/index/rear bumper shots/
I took some detailed pics of the swing outs and latches. I have since changed the latches to carr lane locable latches. no differrent realy they just have a locking feature.
http://www.carrlane.com/Catalog/ind...006280B1713050245221E0107070F1A3C3B285351415F
yeah at the gear bash I was stuck down in the pit. we worked until 2:30 am every night and our host kindly set his compressor to go off at 7am :)
thanks for the ebay link I am putting a bid on it.
Mike Fox rigged up the e-locker, so it is new wiring from the locker to a little black box in my rearquarter panel then i have it switched on the dash by a factory fog light switch. the front will be switched off the existing power atenna switch. seeing how I will be replacing my power atenna for the 3rd time in 4 years it is time to do something different.
cheaper as in more likely to break or as in less expensive :confused:
prolly not cheaper (pricewise) when all is said and done, it will really depend on if i get a used or new 3rd member and what Pice i pay for it, but it will all be toyota. and since i already have a rear e-locker and the wiring harness is there waiting for the front e-locker.
half the fun is collecting the parts anyway.
Jason
Contact CruiserDan here at MUD for a good price on the elocker. When I did the math the elocker came out less than the ARB. I liked the idea that I didn't have the compressor to mount someplace. Also, I used the rear FZJ80 harness. Pricey, but it was long enough to run from the locker into the cab. I'm just using a DTDP switch.
JON
Sweet pics. Thanks. BTW, is that a semi-float axle shaft and wheel mount surface that is used to mount the wheel on? That is a sweet idea.
-Ferg-
the wheel holder is actually from a fj80 axle and the liscense plate holder is a 70's fj40 rear plate holder. and its wired in. came out nice and we made the ladder around it. :cool:
Jason
