How are your axles holding up?
Any stud breakage?
Leaking?
How about those not running the inner-axle seal, any leakage?
Anyone get some aftermarket shafts yet?
My report: I have had my axle on the 40 for about 7 months now. Installed a new ARB & 4.88's at the same time. To date I have has ZERO leakage (flange or diff) and only had one minor problem. A single hub stud broke, all others were subsequently checked and found tight. The single stud "could" have broke as result of hitting something, but not very likely... I re-used all the original hardware and think that is was fatigued and cracked... No biggy. Other than that it has been flawledd, I have run alot of the same trails that took out my semi-float axles (three of em')... So far so good...
dd113?
Ferg?
Mike B?
Bob Devreux?
Any stud breakage?
Leaking?
dd113?
Ferg?
Mike B?
Bob Devreux?
