Those running OEM Full-float axles...
Overlord said:
Now, are 40 series plates still available? Were 60 series plates ever available in the states? The part number I have for 60 series drive plates is 43421-60013. Does anyone know what the part number is for 40 series drive plates/flanges?
Same for 40 series, except for 76-78 birfs 43421-60012. Pre-78 is disco. Newer style still available, maybe by special order. About $50.
Dave
Dave
Do you have a pic of the drive plates?
Cryptic said:
Is it just me or is the ifs hub even shorter still than the regular front? Or is that a rear FF hub?
Too bad you need a spacer to run rotors on the ifs hubs and have it line up with the calipers. Same result as just using wheel spacers to widen your track.
I've never sheared the studs but maybe I just don't have enough torque/tire size. I do occassionally lay a wrench to the nuts to see if they're tight, you guys got me paranoid. :flipoff2:
Regular front. Maybe you haven't broken the studs because you are good in keeping them tight :cheers:
Dave
I used to have a better pic than this, but I'm too lazy to look:
It is round so you can add on or two more pairs of dowels.
Dave
If the drive flange is round and can be drilled for more dowells, then could it be drilled to work with more studs? What if you drilled and tapped for 6 extra studs (forget about the two dowells--take 'em out and drill and tap for studs). So you have 12 studs... If you wanted to, you could do it on the stock axle flanges as well. Wouldn't be the easiest thing, but it just popped in my head and I figured I'd just throw it out there.
-Ferg-
I'm under the impression the dowels are where most of the force is borne, so better yet, put 6 dowels in there :D
Although the 40/60 drive flange is round, there are two threaded holes slightly offset from where the third pair of dowels would have belonged, so drilling the plate here would create an "8" shaped hole that would be pretty weak. These holes are originally intended to separate the flange from the hub when you screw in an 8mm bolt into them.
Dave
beanz2:
"So that means if you run the front hubs on the rear, the axle shafts are sitting closer to the vehicle's centerline. Some diffs will not allow the axles to sit this far in. I know the factory lockers will not, such that you can run front inner axles without a birfield clip or a martack."
Anyone know if a detroit would allow for the shafts to seat that much deeper? And would the fat outer locknut still be deeper than the end of the hub? Can a seal still be used? :confused:
I blew out one of my dowell pins and had to make a threaded hole a pin hole. As I see it the threaded rods keep the keep the axle in and the dowells keep it from rotating on the shaft/hub. My 2 pin fix cost $80 and has kept up just fine over 4K of hard wheeling and hwy driving.
theferg said:
There is a guy or two that run without the axle seals and let the 90W oil the bearings...no grease. Has to make sure everything is tight so the stuff won't just leak out. I was thinking along those lines...
-Ferg-
I run 90 weight in my disc converted FF and it doesnt leak a drop. Frankly after running greased hubs and 90 weight, I wouldnt run the seals even in a stock FF. the oil does a much better job of lubricating the hub, it runs MUCH cooler than a greased hub.
On the subject of allowing the shafts to ride further in, why in the world would you want to do that? you'd loose 50% of the spline engagement ~1.5" length by running the front hubs without custom shafts. Increased wear, and nevermind the tremendous lack of strength. Once the shafts wore, youd have a hell of a time getting them apart, kinda like a 4-speed outputshaft and t-case when they wear alot.
That is what I mean, running shorter front hubs on the rear axle brings the axle-to-hub mating surface closer to the midline, farther into the diff. So you do have your custom axle shafts made shorter to compensate for the hub? Why did you not run the factory rear hubs?
Is this on the stolen blue FJ40, Brett?
Dave
Dave,
I had custom shafts made for them that use drive flanges and a shaft with 30 splines on both ends. they are shorter than stock.
Reason for this is I wanted to do a disc conversion, and the fact I bought it as a bare FF housing about 5 years ago, that had no hubs.
It *was* underneath the FJ40 that got stolen, but I swapped it for a S/F rear because a buyer that was very serious about it wanted a S/F rear for ease of parts finding. So I have it sitting in the gaarage, waiting to find a home in the FJ45, although I will need to send it out to get straightened after I weld on the spring perches and convert back to SUA, since that is just alot of welding on the housing to assume its still straight....
-Brett
I was surfing the net then found an Aussie website which is selling new FF hub for 165 $AUD. I forgot to save link. Doh'. I thought about getting one for spare. Anybody knows the link???
/td
/td
Count me in if you find the link... I have one spare FF hub, but would love to have another. For ~$100, you can't bet new... however I did get 2 used FF shafts, a spare hub, and a set of spare dowels, hub nut/washer assembly for ~$100.
So, sounds like if you were having shorter axles made to run front hubs on the 60 FF rear spindle, you could instead run IFS hubs to widen the stance out back, too...and I'm also interested in double-spline axles to run with drive plates. I'm toying with running 80 FF hubs on my 60 FF rear axle for an RDB conversion, but...
Steve
snip>>The same spacing all the way to the 80 series FF.
Hey Brett, when you used front hubs on the rear, either the spindle doesn't stick out past the hub or did you trim the spindle past the hub?
Dave
<<end snip
sorry for coming in late.. and slightly hijacked, but does the 80 series drive plate fit the 79+ fj40,60,70, mini ?
Sherpa, how far are you along on your thinking on using the 80 series ff rear hub on the 60 series ff housing? I just barely found out yesterday that the 80 series hub would fit onto the 60 series spindle. A buncha Aussies have done it and one guy makes kits using the 80 hubs (or the 60 hubs). My main interest in it would be if the 80 park brake could be adapted some how.... Anyway, go visit this other thread that's going right now for more info...
https://forum.ih8mud.com/showthread.php?p=249872#post249872.
-Ferg-
saw that thread, thanks...BJonRoids pm'd me a long time ago telling me Aussies were using 80 hubs on 60FF rear to widen the stance like IFS hub conversion on front, but was unsure if it was simple bolt-on (now seems that's the case). so I filed that away, thinking I'd 80 hub the rear and IFS hub the front so that I either take advantage of wider stance with pizza-cutters OR use deep-offset wheels like stock 80 and minitruck wheels...and even run large-diameter brake rotors. I'm planning on doing tcase output disk emergency brake, so hadn't really considered 80 series backing plate/drum emergency setup. if only I had funds to pursue this crap, I'd have done it already!!
here's my ideal setup on the rear...60FF housing, IFS hubs (easier to acquire than 80 hubs) with extra dowel pins, 4340 or 300M double-spline axleshafts splined for factory locker, and driveplates. I guess I'd hope that the Sky IFS rotor spacer would put a 60 front rotor where I'd want it for caliper mounting, be no fun to have custom spacers made. use 60 front calipers on plate adapters. will investigate the cut-down knuckle method of caliper mounting, right now I can't picture that yet. might build this, too ;-)
Steve
-Ferg-
Tough to adapt an 80 parking brake, the mounting flange is farther inward, not enough meat on the 60 flange for one of the 4 bolts. I'll see if I can get pics from my home computer tonight and post to the other thread.
Dave
Steve
Why not just use the whole rear 80 series axle, Steve? Too wide?
Dave
