This is what happens when....
OGBeno
11101-59235
Moderator
GOLD Star
Patagonia, Arizona, USA
.....an engine self destructs at 80 mph on I-40.
Customers just bought a re-man long block (not a Toyota--aftermarket engine rebuilders in AZ). Out of pocket for the long block: $3900.
:eek:
Looks like I'll be getting more spares.
:D
I bought a truck with a rod knock, CDan has one and I've heard a couple of older engines at idle with a little something going on.
Time to start rod bearing PMs maybe.
I don't think this was a case of engineering failure. I think this was the case of someone changing the oil and not putting the drain plug back on very well, and IIRC, it backed out after about 120 miles of driving, and well, voila!
It has the intake brace so it must be out of a '95-'97. How many miles?
-B-
I think that is pretty much the definition of "Awwww, crap!":eek: :doh:
My idiot brother did that to my dad's old truck, but that was caused by not checking the oil for 2 years. Retard.:rolleyes:
what kind of engine is that,and what is the silverbox looking thing back of engine
1FZ-FE I-6 Land Cruiser engine. 1993-1997 (North America), 1993-Current (Worldwide).
I assume the silverbox thing you refer to is the intake manifold....other than that, it might be some thing structural behind the engine in the environment behind it.
-o-
WOW!!! Both sides have holes?
Yeah, you can see straight through the block on the DS and then it comes out of the upper oil pan on the PS.
All the way through. As well as other assorted holes in the upper oil pan on the DS and the rod is sitting in the lower oil pan. It blew completely through the upper oil pan....on its "uncontrolled migration"
:lol:
I don't wish this upon anyone.
Yike! Better double check mine (18 FT-LB for the drain plug, right?). as I just did oil change the past weekend.
12k for a longblock 1FZ....Toyota still sell new 3FEs?
12K is for a new long block, not a reman.
But for the price, why would you go in this direction (i.e., backwards?). For that money you could probably do what Gary C. is doing with a 4.7L or a domestic crate engine, or even a diesel.
EDIT: Just checked and the long block assy for a 3FE is no longer available from Toyota.
Mine made it a pretty good ways without any oil pressure... few bearings later, it's still running.
Only explanation is that I have one of the rare super special "no oil needed" 1FZFE's. :D
Emphasis on the maybe.
Main/Rod Bearing PM is not worth it. Huge PITA. Less time to swap in a good used engine.
I've always wondered what it sounds like when a con rod lets loose like that. I'll wait to find out. :D
A customer brought in a 91 FJ80 with 2 holes just like that :eek:
He claimed it happened when he was pressure cleaning the engine at idle, but I think he was revving the piss out of it in a flood or sumthin :hhmm:
Block was filled with water and the crank wouldn't budge cause two rods were hanging out the side :doh:
Installed a junkyard engine and he never came back to pay, so I put a mechanic's lien on it and that's how I got my first Cruiser :clap:
haha, cool story! :cheers:
