I thought about that but toyota issued a TSB for retrofitting r12 rigs plus a bag of small parts and relocating the dryer was not part of the retrofit. My ac works fine in 110 heat.
I'd like to know if there is a reason the dryer was placed low on the later rigs. They already had the upper position worked out, so there must be a good reason.
One possibility might be for the better airflow. The part (reciever/dryer) does more than just extract moisture and filter the refrigerant. There is a reason the unit is shaped the way it is (long tube, inlet and outlet at top, vertically mounted). Besides containing the desiccant....the reciever/dryer has an inlet and outlet tube situated is such a fashion as to always provide liquid refrigerant to the evaporator.
It also serves the function of storing extra refrigerant and oil when not needed by the system (low cooling demand). If you were to move the R/D to an area of high heat (engine compartment/other high heat source) the liquid refrigerant would tend to turn to a vapor. 'Vapor' going through the evaporator won't hurt anything, it just won't COOL. The coolest spot with the most airflow is the best place for the R/D to be.
The reason the unit is mounted vertically....is because gravity separates the liquid refrigerant (and oil) from the small amount of gaseous refrigerant, then the liquid portion is picked up from the BOTTOM of the drier. That is why it is not recommended to turn it horizontally.
I have moved 2 up to the battery compartment, using early 80 pipes and accessories. However, the fitting along the firewall is different, so I make a junction between the drier and the sensor. See thread below, should have swagelok part number i used.
Welding/brazing was very troublesome with leaks, so I recommend using a fitting.
