Oh my god, getting the winch off is a real PITA if you're dealing with a lot of rust (which I am). Cut the cable with a dremel which was surprising easy to get around the spare. After that, things got more annoying. It was definitely a lot harder because I didn't want to take off the cross member due to rust concerns with getting it back on. All in all, it took a lot of scrubbing with a wire brush, heat, and WD40 to get the bolts to move. With all the rust, the bolts were like butter to every wrench and socket and I had to file a couple millimeters just to get to some good metal. I ended up breaking the plastic casing to get a better look at the bottom of the bolts and I think being able to get some WD40 in from the bottom ended up helping. An extractor socket finally found something solid enough to bite into... Easily the hardest simple thing I've had to do in quite a while.
