- Thread starter
- #1,201
Did you try just putting 12 volts to it directly? Its probably just a bad ground or corroded wire.
Not yet. First I gotta get the arms aligned right to get the dang regulator installed correctly. I think I have them right and now I just need to bolt everything back together (tomorrow).
I did look at the 'safety switch' on the driver's side of the tail gate. There is only about 1mm of movement in the switch 'plunger.' There is much more play in the tailgate when it is latched then 1mm. Does anyone know how much movement that 'plunger' should have?
