Had some more splitting issues of my caulk on this side... kinda concerning, don't know why it's splitting. Anyways I cut most all of it out, cleaned it, and shoved some more sika 221 into it. At nighttime may I add, probably won't be doing that againI swear it looked so much smoother when lit up by a floodlight on the side of a house.
View attachment 4203040View attachment 4203036
I don't recall the details of how your pop-top is attached to the body of your Troopie, but a couple of points to consider.
First, the pop-up top and body are different material types; and as the temperatures change, they expand/contract at different rates. This will result in stresses across the attachment joints. Potentially adding to this is the adhesive. The adhesive/caulk will also expand/contract differently than the top or body, but possibly more importantly is its mechanical properties will change with temperature. Most likely decline with temperature.
Due to the material properties and dis-similar CTEs (co-efficient of thermal expansion) at play here, it is likely that this behavior may repeat so you are correct to have a supply of caulk/adhesive with you to treat potential problems.
Second, your Troopie flexes as you drive it. The suspension/frame/body bend and twist together. The suspension takes out the vast majority going down the road. But in un-even terrain, the suspension transfer bending and twisting deflections into the frame and body. These deflections are challenge at the joints between your pop-top and the body.
Limiting the magnitude of un-even terrain that you traverse and frequency that it is encountered will help reduce deflections at the pop-top/body attachments. i.e., Viewing your Troopie more like an RV, rather than a wheeling Cruiser, could be very helpful.
Your trip looks amazing, good luck and I am eager read your reports on this adventure
