Very cool!
Thoughts on this? I was shopping for a wide band and found this which has an electronic boost controller built in.
SCG-1 Solenoid Boost Controller Gauge
I think your right. This sounds like a petrol engine protection function. It does say it is user programmable so you might be able to turn that function off completely.I'm not sure the boost cut function has any relevance for a diesel? Maybe I've misunderstood its function?
I think it is intended for a gas engine scenario where excess boost can lean out the AFR causing excess heat. On This scenario, cutting boost is a fail safe.
This is the opposite in a diesel, if your AFR is lean, you simply get less power, if it's too rich, you either need to cut fuel, or add air/boost, not cut boost.
@IanB. Interesting. My stock pin looks closer to your modded pin but without the extra depth ground.
If your star wheel tension was set up for a stock 10psi and you are running more than that you would think it would be pushed down further but that may be all the travel your pin has hence the new taller caps shops offer like the one I recently posted.
Now people always talked about setting the star wheel tension so your pin would stop at the deepest part of the cut and not go into fuel cut. Are we sure it will actually cut fuel? My pin has shims under it and with my stock tension tuning double the boost the pin would obviously get pushed all the way down but when I had too much fuel my EGTs were increasing as I kept my foot in it. It never acted like the fuel was cut. Wouldn't the pin just go to max fuel quicker with less tension but the shims keep it there and it never pulls fuel?
22 psi on the stock turbo? That's playing with fire I am lead to believe
I share that sentiment. It's more than I'm comfortable with, but I check on it regularly and there's zero shaft play or other signs of impending doom after a year at this setting. I'm finally up to speed where I'm comfortable digging in and doing my own tune, and have the time to mess with it, so it will be set lower shortly.
@IanB
That's a lot of shims. Is that two? I have one on mine that I haven't removed yet but it looks like only one of the thinner ones in your hand.
Hey @IanB,
Have you gotten back in there to check travel on the pin yet? FWIW, you stock pin looks just like mine.
I just turned mine from the most conservative profile half way to the aggressive side. Non intercooled EGTs are decent. But, if I gun it from 0 - 90 mph, I'll get an EGT of 1250 F. It climbs to 1250 and doesn't go any higher but that seems too high to me. I'll just modulate my right foot to keep that from happening for now.
No, it's been a few days since I opened it back up, hopefully I'll get a chance to muck with it some more tonight. I'm also picking up a Gturbo Grunter Extreme from the DHL depot after work today!
