I am reviving this thread - Need some help troubleshooting, mates. Ok.. so I am trying to get my Carb Cooling Fan to run. I rigged it up and hooked it to the battery directly, and it spins, so I know the fan itself works..
When I plug the fan into the green plug, and ground what I think is the temp sensor wire - I get nothing..
The temp sensor is no longer there, so I just have short wire that went in that general direction. That is what I am grounding to a bolt on fender. I turn the key on and off, to see if that will activate the relay, but still get nothing from the fan.
I replaced the relay under the passenger side kick panel with one I bought from a used part dealer - I was told it was in good working order, and it did look like it was in better shape than my old relay.
What am I missing?? Am I going to have to pull wiring harness out and check the whole run of wire? I do not want to do that..
