Build The honey badger build
Post up the details on that TH350, Id like to see what it is.
Started the tear down for this next phase 🫣🙄😳. Steering box is being sent out to Redhead in the morning .
Is that pitman arm seated all the way?
;). No i just put 2 bolts in the box to mock it up for my hoses . I may have a few other things being changed out here in the next week or 2 Stay tuned .
I have always had this contraption of crap and now I have cleaned that up to this . Also I got the hydro assist lines made up tonite . This project is almost complete 🤩
It was probably killed from the burnouts.
I mean I was burning out in the snow so you have a point . Had I had more HP this may have never happened 🤷‍♂️
Well guys I think I have finally grown up 😳. I was 3 seconds away from cutting the lines that go from the pump to the box 😃 and just like that I thought for just a split second 🤔 umm if I move the engine back 3 inches Umm the lines will be 3 inches to short 🤦🏻‍♂️. . 😃.
Probably just a fluke, don’t worry about it.
Who wants to grow up?
Let’s re cap 🙄. It steers perfectly fine no problems at all in the rocks . Me I need to change everything and hook up
My hydro assist 🤩. It runs perfectly fine . Me I need more HP because the guys on you tube have it 🤩. It works perfectly fine . Me I am bound and determined that engine is going back 3 inches . 🤩. My Orion case works perfectly fine ( only has at most 300 miles on it if I am lucky . ) 🙄Me I need an Atlas so it can do exactly what it does now 🤩. In all fairness it will help as my drive line will be straight ( has not been a problem at all . And I did get a 5.1 so a little deeper gearing and it is a stronger t case . . Trans has been a pain since day one. So no argument there it’s going . I am on the fence still if I am going ORI 🤔. I think I will try a revalve first Because I want to hit jumps 🤩
My hydro assist 🤩. It runs perfectly fine . Me I need more HP because a guys on you tube have it 🤩. It works perfectly fine . Me I am bound and determined that engine is going back 3 inches . 🤩. My Orion case works perfectly fine ( only has at most 300 miles on it if I am lucky . ) 🙄Me I need an Atlas so it can do exactly what it does now 🤩. In all fairness it will help as my drive line will be straight ( has not been a problem at all . And I did get a 5.1 so a little deeper gearing and it is a stronger t case . . Trans has been a pain since day one. So no argument there it’s going . I am on the fence still if I am going ORI 🤔. I think I will try a revalve first Because I want to hit jumps 🤩
Yep.
It was just a fluke. Nothing to worry about.
Nice it kicked in when it did though and saved you some lines and headache down the road.
Hey maybe it was a sign?!?
