Ok Shroud definitely helped. But sitting at idle it would still slowly creep up Driving it’s fine . Unfortunately this will never really be driven a lot on the road and will be slow moving so . I took a break and thought hmm let me try something . I took the trans cooler off the front and held the electric pusher fan I had bought up and that is the ticket. Temp came down and held steady. At 178 . Now the issue with that is space This trans will be the death of me I am telling you . I took the mesh screen off and that gives me the room I need . So I loose the Toyota emblem . But I think I can make something to get it back . Bottom line is I have a Toyota emblem and sit in my garage Or I run a pusher fan to help at idle and not worry about over heating on the trail I have exhausted all other options with this thing I think .
That is what i am thinking. i will make it so its on the back side of the bezel. Once the winch is mounted it covers most of it anyways. When the time comes I will pull this engine and trans /t-case.
It would still be to tight I think . I will use this as motivation to start collecting phase 2 parts . What ever goes in next I can assure you it will be mounted back 3-4 inches Unsure what trans I will go with yet but it will not be a TH400 . Great trans but not for a 40 .
In fear of some overlander/jeeper Mistaking this and putting one of those ducks on it I figured I better get busy with the next art project . I had to clearance a little bit of the bib to clear the fan . It’s all covered by the bezel .
Plan on doing some wiring this weekend. And clean things up . One good thing is with the sniper it has built in fan control for the electric fan . Thinking of the positive here lol .
Wheels are KMC Machetes 17 inch. i powder coated the rings black . The tires in that pic are STT Pro. 37 inch but i am running 40 inch Maxxis Razr now They work well i just am not a fan of how they look . I had planed on running Mickey Thompson Baja Pro x.
Wheels are KMC Machetes 17 inch. i powder coated the rings black . The tires in that pic are STT Pro. 37 inch but i am running 40 inch Maxxis Razr now They work well i just am not a fan of how they look . I had panned on running Mickey Thompson Baja Pro x.
Cut more crap off If I never have to grind and drill a rivet again I will be ok . Temp Wired up the fan to the sniper it works . Now I can wire it in for good . Put my bumper on and mounted the winch . Did a little more welding on some brackets.
Aww this is so fun . Wiring I made a plate to cover the holes where the fan was since I mounted my battery in that location . I had to fab up some brackets to help keep the battery from moving anyways . Then I added some terminals so I do not have 300 wires running off the battery . This really cleaned things up . I actually have a fuse block inside now to add things like Christmas lights and feet massagers We are making progress now
Couple weeks to go . Toying with the idea of making a custom center council . Or probably just get a tuffy box To mount my switches in . I can’t reach the dash good when I am strapped in the harness so I want something I can easily operate.
Twin sticks are in place. . Compressor is in . Then I started cleaning and polishing . I think I will just trailer it to the trails. Take a pic then hike the trails . . I need to pull the cage . And get it PC and raptor line the inside of the tub. But that’s is just cosmetic stuff. I want to get it in the rocks and see what or if I need to change anything first
