WE HAVE STICKINESS!!! (Did I miss something? has it been this way for a while now?)
jhs55 said:...My question is how you attached the 'window felts', as the new felts do not have the holes for the clips...I was going to use a two-part epoxy...How did you do it?...
Thx again...![]()
jhs55 said:ok...i think i follow...so do you then 'pull back' the felt itself, drilled the holds, reinserted the 'fasteners' and glued the felt back onto the metal part of the strip, and then fasten it to the door?...
thanks for your help my man...
A very timely post for me as I am planning the next assault on Pigwald !heath,, how did you attach the door weatherstrip?? mine is a very very tight squeeze trying to get into that steel channel. is that what you did? just patience?
Piggy hopefully will be done at the bodyshop and interior by July 4th What was the grand total of the parts from JCWhitney?
I know, I should get a calculator...
The tailgate outer weatherstripping that goes across the top of the tailgate and down the sides IS available from John in Cambria, CA. I just got that piece from him 2 months ago and it fits perfectly and is a copy of the OEM!
