- Thread starter
- #181
Valid point there. I think the proper mounting with hydraulic mounts is the best you can do. But, I was curious since I hadn't seen many on 4bts.
With the external voltage regulator giving me issues unless it was connected directly to the battery and directly connected to the battery it pulls 3A and will deplete the battery. So I decided to add a relay and use the ign source for the relay with normally closed to the regulator. And since I was on the wiring kick I ordered up marine grade wire, lugs, and a blue sea 12 circuit fuse box. Ran 4ga dedicated from the alternator to the battery and a 4ga to the fuse block. All lugs were soldered on and not crimped. I hate crimped lugs. And ample heat shrink.
Is this going to be ready for the LSLC Round-Up?
Again, my fuel cut-off on me and my inline filter gets some crud in it but not enough to stop the flow. I don't think I need an inline pump.. Anyone with a 4bt had that issue? I'm dreading it but I might have to pull the tank and get it dipped. Maybe it just has that much stuff that gets tossed around as it gets to sloshing. Luckily I was heading home and was going downhill and could coast.
