Likely just leaves enough room for the pin.
Al:I want a set of these springs for my FJ40. My inquiry a few months back revealed the stock was not yet available but since then, and the springs becoming available , I have used my 2024 Land Cruiser funds allotment for disk brakes, 3.70 differentials, Holley EFI, HyperSpark ignition, double seal output shaft, u-joints, interior updates and numerous $100.00 this $100 that and $100 something else ….etc etc .
I desperately need to add this based on everyone of the reviews I have read. My old cartilage doesn’t cushion my bones as well these days. I hate the sounds I make claiming in and out of any of my vehicles
Al:
Nice job coining a new acronym: LCFA (Land Cruiser Funds Allotment). Of course, this is not to be confused with the ULCFA (Unauthorized Land Cruiser Funds Allotment) which is often tapped into in the wee hours.![]()
I’ll join that minority, I don’t really want to lift my 40. Years back I could hop right in with a 4” lift but now I have a bit more trouble climbing up….and it really ain’t that tall. She’s stock heightI wish these were available in 0-1" lift, but I realize I'm in the minority. Still, a very cool option!
Maybe, by putting the short leaves directly under the perch, you can lower your ride-height or fix Cruiser-Lean?
SOA is for 'trails.' A SOA-lift dwarfs 35-inch tires. At this point, ride-height is almost trivial, as the axle itself is lifted from just running bigger tires, providing much needed clearance for the rotated differential (double Cardan driveshafts). A set of oversized tires, run at beadlock-type pressures, is a very active part of the vehicle's suspension.Wonder if they ride better than a well done SOA. Anyone who owns them happen to ride in a SOA fj40 and could compare?
I believe the springs I currently have are 0" lift (but I could be wrong). 33x9.5's (Kenda) fit the front without rubbing. The rear rubbed over large bumps so I added a 1" extension to the bump stops. No rubbing since that extension but only on-road testing. The OME seller I spoke with assured me that 33's would not rub with their 2.5" lift. Guess I'll have to write TT and get a similar assurance if I go that route. With a 2.5" lift, I was expecting a minimum of 2.5" lift even at full compression, not just a 2.5" extension of travel. Anybody know if my definition is correct on this or I should adjust my expectation?SOA is for 'trails.' A SOA-lift dwarfs 35-inch tires. At this point, ride-height is almost trivial, as the axle itself is lifted from just running bigger tires, providing much needed clearance for the rotated differential (double Cardan driveshafts). A set of oversized tires, run at beadlock-type pressures, is a very active part of the vehicle's suspension.
My buddy lost a knuckle, just seconds after doing 70 mph on a freeway off-ramp, on his SOA FJ40. I'm not sure if it was from the cut-and-turn, or something different. He unloaded the built SOA FJ40 rig for a mostly factory SOA '85 Toyota pickup with mild lift, and started building a Willy's CJ flat-fender.
If the parabolic-springs are able to articulate like a set of proper coils, I'd imagine that the biggest tire you can squeeze under a 2+-inch lifted 40 is about 31-inches. Without moving the steering box and drag-link, I was rubbing 33x12.5 with a similar (stiff) Rancho lift, also rubbing on the rear wheel well.
So, why are leaf springs (from a 'kit,' or from the factory) so stiff on a SUA? Axle wrap (no links), lack of sway bars controlling body-roll (40s and 45s), spring sag over time. These are good reasons to be a skeptic. Maybe, after half-a-century, someone finally made a proper lift for the leaf-spring Cruisers, but, it is going to need to be time-tested. Thirty-six posts into this thread, and no reports from the 'trail,' stay patient is what I'm thinking.
Due to the wider (8-inch) wheels, and 12.5-inch BFG Mud Terrains (circa 2001), the comparison isn't fair, on my part. Tire width and wheel width / offset changes the moment of axle compression forces. Also, bushings also play a role. Look at SOR heavy duty springs, the eyes are made so the pins have a bit more wiggle because the polyurethane is like double thickness above stock.I believe the springs I currently have are 0" lift (but I could be wrong). 33x9.5's (Kenda) fit the front without rubbing. The rear rubbed over large bumps so I added a 1" extension to the bump stops. No rubbing since that extension but only on-road testing. The OME seller I spoke with assured me that 33's would not rub with their 2.5" lift. Guess I'll have to write TT and get a similar assurance if I go that route. With a 2.5" lift, I was expecting a minimum of 2.5" lift even at full compression, not just a 2.5" extension of travel. Anybody know if my definition is correct on this or I should adjust my expectation?
