did you put it front or rear?
Rear
Yeah, I got a sorta hybrid for the troopy w/ 3 B pillars and cross ties. Little concerned about the frame tie in w/ also mounting it to the body like stock in order to allow the body to roll (ie lean) a bit. Will probably come up w/ something in between. Anyway, good product thus far. Let you know when I get the d@mn top offto get it welded.
There are more than a few folks in this area that can probably do it for you. In the club itself Will M does some welding and Landry has a machine... but no gas (welding gas that is)
me
Scott,
Look at Poly Performance.com - Fox Shocks, Donahoe Racing, Beard, CTM, Currie Enterprises, Edelbrock, total Chaos, Ramsey winch, Walker Evans, Wilwood, Mastercraft, and more... they offer a cool frame tie-in set up. Might be just what you are looking for to allow the body a little flex. The have some cool on board air set-ups too. I am going to get one of the viair set-ups.
Later,
Later,
Got the springs on. Both shackles are folded under though and I can't jack it up high enough to straighten.
Any ideas? Hi-lift? Screwed?
Thanks for answering the call today Larry, Scott, thanks for the jack and stands, Corey, thanks for calling and offering the help but I was doing good.
Goodnight and happy Easter.
MC
Will try to ride by if you think you need. Inverted again ...... It all seemed lined up right, the shackle leaning just a little to the front. When I tried to put the u-bolts on though, the way I compressed the springs to bolt them down, it folded it up to the front (opposite of what that rear driver had been doing). Both folded up like that when I was done......
has anyone thought about putting a full time lock like a spool or something like that up front where it would not affect onroad performance?
Got into some mud Friday night, without the top on (not recommended), and found out that front tires want look in. Everything spins drive shaft, cv shafts, but not the tire. Can I rebuild the hubs, replace them, or is there something else causing this?
