Tattons gone?
Austin, TX
Looking for a DC front ds and noticed tattons is gone off of ebay. Anyone have knowledge of this? Wits end is out of stock of the landtank shafts, I know tom woods does custom dc shafts but am not sure, I believe others had to get their flanges milled to fit with enough thread engagement.
Whats the easiest solution here? Take my front off and to a ds shop and have them use my core?
you can always buy a tacoma DC front shaft from @beno ad have it shortened
There should be a local shop to make one for you, that would be my first choice.
What is the PN for the Tacoma DC shaft?
I've been running a Tom Woods front DC shaft for 6 years and no problems, yet... Not as high quality as OEM but does the job.
thanks @RFB , is it the rear or front? I thought the rear had the DC. You have(had) a tom woods and had issues no?
@beno would be happy to order an OEM DC unit for you, if possible. I have a pretty good shop near me that could modify to fit my 97.
Next batch about a week or so out. How soon do you need one?
You need a rear 95 to 02 extra cab or double cab taco shaft, then just retube
  • Like
Reactions: RFB
We're constantly working on stock levels. So if we're out of stock today more cores are on their way. In fact I'm picking up two shafts this afternoon and shipping them out to customers right after.
We now automatically replace the u-joint at the slip yoke and warranty the shaft for 12 months.
But as stated any competent shop can retube a shaft. It's just important that they use metric tubing.
I literally just ordered and received a Tatton's unit, I ordered by calling them though as I wanted to give exact measurements to them. I'd imagine if you call them they are still making them. Took 2 weeks from when I ordered till I received mine and thus far seems to be doing the job for me.
... It's just important that they use metric tubing.
I guess it depends on the goal? The ones we work on are regularly wheeled, so go stronger, .120" or better tube. Just turn the yokes to the needed size and can use whatever, we go with domestic size DOM. Not bomb proof, but can handle some ground contact, unlike the stock muffler tube, that folds like a house of cards with even casual contact.
The driveline shop I use stocks .090 wall metric tubing and this shop doesn't have a lathe. While looking for a shop I was rejected repeatedly because they didn't have the metric tubing. At least around here the shops seem to only want to do a straight retube and nothing more.
Maybe in a more 4X4 oriented area the custom stuff is more readily available. But I would still mention it.
Tomwoods, good fast all new and to your specifications, Mine was at my door in 2 or 3 days for around 400.00
The only downside I can think of is it’s not MrT’s
In a previous life I was a motorcycle guy (before I wisened up), the panty chopper had thongs constantly getting caught im the belt. Legit problem.
Went with @landtank and @NLXTACY coordination. I just couldnt bring myself to spend less. Hopefully this adds some horsepower and increases mpg's.
Being 250.00 lighter in you wallet you should at least go faster.
